strech Occasional Visitor
Posted: Sun Jul 31, 2005 9:05 pm Post subject: LAND ROVER DISCOVERY HEATED SCREEN & TOM TOM 300? |
Any one know if a tom tom 300 will work in a discovery 2 with heated front screen
any help guys |
paul-pearson Occasional Visitor
Posted: Mon Aug 01, 2005 12:49 am Post subject: |
no landrovers come with this type of screen so you will be fine. |
Posted: Mon Aug 01, 2005 12:53 am Post subject: |
oh wait i didn't read your 1st coment right " heated front screen " i thought you meant reflective. i wouldn't have thought so you will probbably need the externall antenna. |
sgould Frequent Visitor
Posted: Mon Aug 01, 2005 1:17 am Post subject: |
The GO seems to work OK in other Ford cars with the fine wires embedded in the screen. Does the Discovery have the same type?
The problem ones seem to be the coated windscreens that reflect heat. Mostly French. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Mon Aug 01, 2005 4:02 pm Post subject: LAND ROVER DISCOVERY HEATED SCREEN & TOM TOM 300? |
yes it has the fine lines through the screen  |
stormstorr Lifetime Member
Posted: Mon Aug 01, 2005 10:36 pm Post subject: |
Hi Strech,
I've had a classic and a 700 Go in my 2004 Discovery. I found that I could get a fairly good signal through the heated screen, but it did drop off regularly, and always at the wrong time! I cured this by fitting an external arieal kit. Ran it accross the dash, under the door seals and onto the shelf under the rear side window. Works a treat! |
