Pocket GPS World :: View topic - cant use 7 digit postcode tomtom 5
stvme2519
PostPosted: Sun Jul 31, 2005 1:20 pm    Post subject: cant use 7 digit postcode tomtom 5 Reply with quote
just got tomtom 5 and still not letting me use 7 digit postcode entering can any 1 help
PostPosted: Sun Jul 31, 2005 1:31 pm    Post subject: Reply with quote
Create an empty folder in the root of your storage card and name it "TOMTOM" without the quotes.
easyrider
PostPosted: Sun Jul 31, 2005 1:34 pm    Post subject: POSTCODE Reply with quote
Hi As far as I know Postcodes only contain 6 digits
Hope This Helps
PostPosted: Sun Jul 31, 2005 1:44 pm    Post subject: Reply with quote
The (UK PostCodes) can contain up to 7 digits actually!
Hoppy
PostPosted: Sun Jul 31, 2005 2:28 pm    Post subject: Reply with quote
Follow Darrens advice create an empty folder on your SD Card called TOMTOM it's been mentioned loads of times.
victory
PostPosted: Sun Jul 31, 2005 2:47 pm    Post subject: Reply with quote
one thing i found which solved my problem with postcodes not working was that the file great_britain.postal was not in the zip directory on the memory card. once i borrowed* the 8mb file from a mate and placed it in it worked..
i must point out that he had the great britain plus map so ive emailed tt to find out why on earth it wasnt included on my card at all... 8O
PostPosted: Sun Jul 31, 2005 5:04 pm    Post subject: Reply with quote
The PostCode functionality is only available as part of the map upgrade which needs to be purchased, it is not provided as part of the v5 upgrade itself.
delboy102
PostPosted: Sun Jul 31, 2005 8:08 pm    Post subject: Reply with quote
hi, I cant get it to work either, I've installed tomtom 5 and I can only enter 4 digits, I tried creating a folder called TOMTOM on the root of my SD card but that didnt help either.
I looked in the SD card and I cant even finda folder called zip, any ideas?
PostPosted: Sun Jul 31, 2005 9:05 pm    Post subject: Reply with quote
Did you read my post immediately before yours?
If you have not purchased the update map set then you will not have the ZIP folder that comes with the it. Simply updating to v5 does not bring this functionality and without the update map set you won't have 7 digit PostCodes.
delboy102
PostPosted: Sun Jul 31, 2005 10:25 pm    Post subject: Reply with quote
I didnt update from 3 to 5, I actually brought the full tomtom navigator 5.
Do you reckon it will work if I just copy someone elses zip folder onto the card or something?
kissinuk
PostPosted: Mon Aug 01, 2005 1:02 am    Post subject: Reply with quote
There is a seperate option on the setup program to install the postcodes. Just put in your Map CD and you should find the option under the Great Britian map somewhere.
PostPosted: Mon Aug 01, 2005 7:50 am    Post subject: Reply with quote
It's on CD1. Choose Add Maps, Great Britain, Great Britain Postocodes.
TT Via 135 App 12.075: Europe Map v1135
Hoppy
PostPosted: Mon Aug 01, 2005 6:33 pm    Post subject: Reply with quote
It won't be on CD1 if he brought TT5 not the upgrade it comes on SD Card I think.
scaseman
PostPosted: Mon Aug 08, 2005 6:19 pm    Post subject: Reply with quote
I'm suffering the same problem, however I have installed the postcodes from the 'install maps' section and it has added the great_britain.postal file in the zip folder Sad anyone help??
PostPosted: Mon Aug 08, 2005 6:29 pm    Post subject: Reply with quote
And do you have a 'TomTom' folder in the root of your storage card?
22.094 (25 Sep 24)
