Pocket GPS World :: View topic - BT Receiver
BT Receiver
Colin58
PostPosted: Sat Jul 30, 2005 10:13 pm    Post subject: BT Receiver Reply with quote
I am looking to upgrade my system with a new BT receiver, I have a HP 4700 and Tom Tom 5, any recomendations on the best unit out there at present.
Maxi
PostPosted: Mon Aug 01, 2005 1:24 pm    Post subject: Reply with quote
I'm more than happy with the Tomtom Bluetooth MKII receiver. Always get plenty of satellites, works anywhere in the car and you know theres not going to be any compatibility issues. Its small and looks pretty good too :D
Colin58
PostPosted: Thu Aug 04, 2005 12:54 am    Post subject: Reply with quote
Thanks Maxi,
I thought this looked a good choice but wanted to hear somebodys opinion of it. The only minus I can see is that the battery is built in and not replaceable.
Col....
ttrevor
PostPosted: Thu Aug 04, 2005 12:24 pm    Post subject: Reply with quote
I have just purchased a Holux 236 slim BT, and it is brilliant you can also have it wired if you require.well worth a look before you decide.i am morethan pleased with mine :D
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
Maxi
PostPosted: Thu Aug 04, 2005 1:31 pm    Post subject: Reply with quote
Colin58 wrote:
Thanks Maxi,
Col....
I'd guess that having a replaceable battery makes for a much larger unit.
Privateer
PostPosted: Thu Aug 04, 2005 1:43 pm    Post subject: Reply with quote
Hi Colin58,
If you want a replaceable battery in a Bluetooth GPS receiver then have a look at the fantastic GlobalSat BT-338. The dimensions of BT-338 are approximately 42mm (width) 72mm (length) 23mm (height)
I’m very happy with the performance of my BT-338.
Robert.
Garmin Camper 770 LMT-D
alFR
PostPosted: Thu Aug 04, 2005 2:01 pm    Post subject: Reply with quote
Robert, are you using TT5? Any problems getting it to talk to your 338?
Privateer
PostPosted: Thu Aug 04, 2005 2:21 pm    Post subject: Reply with quote
Hi alFR,
I'm using TTNav 5 on an iPAQ 4700 and 2210. The BT-338 works well with TTNav 5 on both of them.
Settings are (for the 2210):
Other Cable NMEA GPS
Baud Rate 38400
Bluetooth serial port COM8
Robert.
alFR
PostPosted: Thu Aug 04, 2005 3:00 pm    Post subject: Reply with quote
Cheers!
Al
DavidHobbs
PostPosted: Thu Aug 04, 2005 4:51 pm    Post subject: Reply with quote
Where would be the best place to look for a new BT receiver?
Colin58
PostPosted: Thu Aug 04, 2005 9:10 pm    Post subject: Reply with quote
Thanks for all the suggestions people. The bt 338 souns excellent. The only reason I like the idea of the replaceable battery is if the inbuilt one fails, if this occurs it is a big plus to be able to replace it rather than return it to the manufacturer. Any suggestions on the bet source for the Bt 338 or should I just go and search.
Col...
Colin58
PostPosted: Thu Aug 04, 2005 10:20 pm    Post subject: Reply with quote
Has anyone had any experience of the Rikaline 6033. I read an add on one of the internet retailers which suggested it was a higher spec that the Globalsat. I would be interested to here anyones reviews.
Col....
DavidHobbs
PostPosted: Fri Aug 05, 2005 5:03 pm    Post subject: Reply with quote
Col...
I think your battery idea is a smart one.
keithmroberts
PostPosted: Thu Aug 11, 2005 7:19 pm    Post subject: Reply with quote
A word of caution.
I have the same setup, IPAQ4700, Tomtom 5 and the BT338.
I had problems upgrading from TT3. It is important to note the small upgrade to tt5 that makes it verssion 5.01. If you software is 5.0 you can pull it down from the TT website.
I also found it necessary after advice from TT to reboot the receiver, by removing the battery, as I could not persuade the systems to work together until I had done that. Now - its excellent - but I had a bit of a struggle getting there.
Colin58
PostPosted: Sat Aug 13, 2005 1:19 am    Post subject: Reply with quote
Thanks Keith, I will take note of this. Reading through the forums there seems to be problems wit Sirf III chipsets at present, I think I will hold off till the s/w issues are resolved.
Col.....
22.055 (29 May 24)
