Pocket GPS World :: View topic - Speed cameras download.
galtom
PostPosted: Fri Jul 29, 2005 4:25 pm    Post subject: Speed cameras download. Reply with quote
How can I update my Quest with list of Speed cameras in UK?
I have downloaded files form this web side, but I have no idea what to do next. There was something about POI as cameras for Quest but I do not understand it. HELP! Smile
farzad
PostPosted: Fri Jul 29, 2005 5:03 pm    Post subject: Reply with quote
Hi galtom
You need to down load from the following site for your Quest :-
http://myweb.tiscali.co.uk/walterwright/
The instructions are there as well.
This excellent overlay map was put up by WiRED.
Do a search for *wired* on this site to see the history.
Good luck
galtom
PostPosted: Fri Jul 29, 2005 5:20 pm    Post subject: Still no succes :( Reply with quote
I've done what u said. Now in Mapsource I have two separate maps. Original with no cameras or if I choose new one - only cameras and nothing underneath Sad. How do I put all cameras on the streets?Smile I mean on my map that has street names and all the rest?
Skippy
PostPosted: Fri Jul 29, 2005 8:41 pm    Post subject: Reply with quote
I don't think you can see both maps together on the pc.
Click on "Receive from device", select Maps and then click receive.
Now switch to the speed cameras map and select the map (use the yellow edged polygon tool in the toolbar), then click on download and download the maps back into the Quest.
The main downside is that you have to download the entire map set again and this takes a little while.
Gone fishing!
locksmith
PostPosted: Tue Aug 16, 2005 7:12 pm    Post subject: Reply with quote
Tried to run the setup.exe and got this
C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and Microsoft Windows applications. Choose 'close' to terminate the application
Any ideas?
