alix776 Pocket GPS Moderator
Posted: Sun Sep 14, 2003 8:04 am Post subject: ttn 1 locking up |
can anyone help ttn1 is locking up after about 1 or 2 hour into jrney when i say it lock up the whole ppc freezes im using a jornada 568 with mmc battery 128 mmc card with uk map on and a pretec cf gps can any one help[ _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
oh i forgot in useing gps assist latset version _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
DavidW Pocket GPS Moderator
I suggested the MMC battery and a MMC as a possible set up to someone with a Jornada and a CF GPS in this thread earlier this evening.
nicknick responded saying that this combination caused crashes with TomTom Navigator on his setup. It sounds like the MMC battery / MMC combination just isn't reliable enough for TomTom Navigator use, somewhat akin to the problems some have had with SD cards.
I suspect the only 'fix' is, as nicknick found, to put map data into main memory. That's going to be tight on many people's setups. You could try complaining to HP, but as the Jornadas and all their accessories are discontinued, I wouldn't be hopeful of a fix, particularly as the problem may simply be that MMC is not that fast anyway, and navigation software tends to put pretty high demands on your storage hardware.
Sorry this is not good news
David |
Taking GPSAssist off your setup may help. One of the Pocket PC staff has posted previously that GPSAssist doesn't work well on an older iPAQ for him. It may just lift the loading on your hardware sufficient to prevent crashing.
That's certainly worth trying before resigning yourself to it being a hardware problem.
David |
aleast it frees up with sotf reset no fun in a 40 tonner _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
nicknick Regular Visitor
Alix,
As David has said this is exactly the problem I experienced.
I was alleviated a bit by formatting the MMC card with 16k clusters as suggested in another thread (using Storage Tools)
As I'd had it for a while I made the switch to an Axim and this is much better
PS. I wasn't using GPS Assist _________________ Nick |
right i think ive sorted this ive removed gpsdriver 2.05 and repladed it with version 1.36 this seams to have sorted the problem only stopped a couple of times since doing this on sunday afternoon did tarleton-wellingbourough-swindon-tarleton running with guidence and with out gps assist it seams to be fine for now wonder what will happen if i upgrade to nav2 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
