Oldboy Pocket GPS Moderator
Posted: Sat Jul 16, 2005 6:47 pm Post subject: |
Yes. You can call it what you like, as long as remember when you update next month to do the same. You'll have to rename the BMP's to the same name so that they remain associated. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
ned1 Regular Visitor
Posted: Sat Jul 16, 2005 9:14 pm Post subject: |
Thanks,
I 'll do that and see how it work out over time unless someone else has a better idea
Ned |
sgould Frequent Visitor
Posted: Sun Jul 17, 2005 12:11 am Post subject: |
You can call them anything you like as long as the name of the bmp is changed to match. Otherwise the right icon won't show with the warning. You will probably get a brown square. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Andy_P Pocket GPS Moderator
Posted: Sun Jul 17, 2005 8:38 am Post subject: |
Oldboy said: Quote: | When doing the Mobiles, the problem arises because there is no speed related icon. Then you have to count carefully, or press and hold the selection |
OR..... its easy to make your own icons for the mobile cameras with the speeds marked on them.
There are some examples in the pack you downloaded in a folder called "alternative bmp filess"
For some reason, I like the ones in the "Andy_P" folder :D |
Posted: Sun Jul 17, 2005 8:42 am Post subject: |
Sorry Andy,
Andy_P2002 wrote: | For some reason, I like the ones in the "Andy_P" folder :D |
I wonder why. _________________ Richard
Posted: Mon Jul 18, 2005 12:25 pm Post subject: |
Hi all, again
After loading the safety cameras (speed zoned) onto my ttg
and setting the distance warning I came across one mobile with
TBA next to it, is this a spare !!,
Ned |
Posted: Mon Jul 18, 2005 5:01 pm Post subject: |
The tba cameras are the ones where no one has reported the speed limit. As you were there you could do that for us!! _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Posted: Mon Jul 18, 2005 9:34 pm Post subject: |
sgould wrote: | The tba cameras are the ones where no one has reported the speed limit. As you were there you could do that for us!! |
Sorry, but I was not there I was talking about the setting up of the my ttg not driving past a tba.
Ned
ps Now I know, if I do I will |
Posted: Wed Jul 20, 2005 8:56 pm Post subject: |
Hi all
What I would like to know is, are the alternative bmp files (khan file) a straight swop for all the speed zone bmp files, can I just select all and paste into the folder or copy and replace them one at a time.
Ned
ps also will they need to be resorted at the next up-date !!! |
Posted: Wed Jul 20, 2005 9:45 pm Post subject: |
ned1 wrote: | Hi all
Ned
Yes you can just Select All and Paste into the Folder. You will be asked if you want to Replace 'old' with 'new'. In this case Yes will be the Response.
At the next update just copy the .ov2 files over. _________________ Richard
Posted: Wed Jul 20, 2005 10:02 pm Post subject: |
Thanks for that Richard
also can I add the alternative wav files and keep all the sounds or will I have loose the same # as I replace!!
Thanks once again
Ned |
Posted: Thu Jul 21, 2005 6:01 am Post subject: |
The TTGo series don't use .wav files so you will always be limited to either the original warnings or the modified sounds that can downloaded from this site. _________________ Richard
Posted: Thu Jul 28, 2005 3:19 pm Post subject: |
Hi all,
I have all the speed zones, distances, camera type etc, set in my ttg 300, what I am not sure about (having not up-dated yet) On the monthly up-date will I have to reset all the above.
Ned
ps this site is |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Thu Jul 28, 2005 6:11 pm Post subject: |
ned1 wrote: | Hi all,
Ned
ps this site is |
No just copy the new files over when you update and overwrite all old ones. The wrnings will stay set. |
