jmoo Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_043.gif)
Posted: Mon Jul 25, 2005 7:58 pm Post subject: Need Help with BT-338 and Dell Axim x50v |
I just received the BT-338 after reveiwing the information listed here.
I have spent the last 2 hours trying to get this to work. I have read the instructions. One set of instructions says to set baud rate at 4800 and the other says 34800???????? I can not get this to work. I have called US Globalsat and they said send an email request for tech support. I really wanted to get this working and I can not get it set up. Can anyone who is using this device please help me out? I am at a loss as what to do. I am about ready to send this back and try something else.
Thanks for any and all help on getting this operational.
Jmoore ![Exclamation](modules/Forums/images/smiles/icon_exclaim.gif) _________________ Jmoo---Learning as you go! |
footman Regular Visitor
Joined: 05/06/2003 06:48:54 Posts: 150 Location: Camberley, Surrey
Posted: Tue Jul 26, 2005 8:32 am Post subject: |
I have exactly the same setup and it works perfectly. What GPS software are you using? I'll try to help more after work tonight.
Laurence |
Posted: Tue Jul 26, 2005 8:13 pm Post subject: |
I also seem to have a problem with the bluetooth freezing up the axim. I have installed the new updates for this unit. When I am in the bluetooth manager and trying to connect I can not get the link to open so I can connect. If I can even open it, it takes for ever. If I can not get it to open I have to do a soft reset and then it will finally work. Any thoughts on this?
#1) When I am in the Bluetooth browser I see "? BT-Gps-3090F8" what does this mean? I can not hold down on this to get it to open up. Both the GPS unit and the axim have a blue flashing light.
#2) Under Bluetooth general there is a line on the bottom of the page "Use Bluetooth Manager to get connection. I can not hold down on this to get it to open?
#3) I followed the instructions for getting the GPS to connect to streets and trips. streets and trips does not show port 7. Also there is no place to set the baud rate.
Am I having a heck of a time or what.
Thanks for the help I need to learn this and this is a good source. _________________ Jmoo---Learning as you go! |
Posted: Tue Jul 26, 2005 8:25 pm Post subject: |
is "streets and trips" your only mapping application? if it is then what version is it? It may not support bluetooth. |
Posted: Tue Jul 26, 2005 10:29 pm Post subject: |
For right now I am only using streets and trips 2004. Any suggestions on how to get all of this working?
Thanks _________________ Jmoo---Learning as you go! |
Posted: Tue Jul 26, 2005 10:39 pm Post subject: |
I take it that you have installed pocket streets? |
Posted: Tue Jul 26, 2005 11:10 pm Post subject: |
That is correct.. _________________ Jmoo---Learning as you go! |
Posted: Tue Jul 26, 2005 11:44 pm Post subject: |
Well, I have turned on my BT338 and the middle green light is flashing. I have turned on BT on the Axim. I have opened up pocket streets, clicked on "menu" and the clicked on the GPS tab. I click on "GPS configuration" and I am presented with a list of COM ports numbered 1-9 and I can select COM 7.
can you do all that? |
Posted: Wed Jul 27, 2005 12:01 am Post subject: |
ok I have done that and this time is see ports 1 3 7 8 9. I have selected com 7 and clicked ok. Now for some reason I am getting a page that shows the blue tooth gps. Now what do I need to do? _________________ Jmoo---Learning as you go! |
Posted: Wed Jul 27, 2005 8:34 pm Post subject: |
can you explain exactly what you see in that window? |
Posted: Wed Jul 27, 2005 10:51 pm Post subject: |
Thank you for your help with this.
I received a replacement Axim this morning and low and behold it works and the bluetooth appears to be working correctly. From the info you gave me I now have a working unit.
I have gotten this figured out it appears. Maybe a bad Axim or something like that.
So now on to other things. Streets and trips works pretty good. Any suggestions on something else. I would like to be able to add places and then make a note or enter the grid and save it to my desktop?
Thanks again for your help ![Exclamation](modules/Forums/images/smiles/icon_exclaim.gif) _________________ Jmoo---Learning as you go! |
Posted: Wed Jul 27, 2005 10:59 pm Post subject: |
very glad to be of help. although I have pocket streets on my system Ive never used it.!
best wishes
Laurence |
chowroc Occasional Visitor
Posted: Fri Jul 29, 2005 6:11 pm Post subject: Urgency!!!! Help!!! |
I have an Axim 5 with BT-338 and they were working fine two three weeks ago but they stopped work suddenly about two weeks ago. This is not only happened to me. My friend has x50v and bt-338 also had exactly same situation and stopped working on the same time. We all have working condition and without change any configuration and it stop working. My navigation softwares (tom-tom, belkin, and matropolis) could not find GPS device but my bluetooth manager detect my BT-338 and binding it OK (my BT-338 both lights blue and green are both blinking). I also tested it on my notebook computer and I got the same result. The notebook was working fine before. I don't know it was coinstantaneous or not they stopped working after London Bombing. Your help will be appreciated. |
Posted: Fri Jul 29, 2005 8:02 pm Post subject: |
many things have changed because of the London bombs but not GPS!
Have you tried pairing the 338 on your Axim? |
Posted: Mon Aug 01, 2005 5:46 pm Post subject: |
yes, I have paired my GPS with my AXIM successfully but my navigation software still can not find my GPS device. |
