bigyun2000 Regular Visitor
![](http://www.bigyun2k.karoo.net/look.gif)
Joined: Oct 12, 2004 Posts: 64 Location: Rotherham, South Yorkshire
Posted: Tue Jul 26, 2005 7:40 pm Post subject: |
Thanks Jim-Bob
Yes thats fine. Your a star. _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
Version 9.510 (2039, 4/4/2013) | OS: 842337 | MAP v910.4892 | iPad Mini | iPhone 5 | |
Jim-Bob Regular Visitor
![](modules/Forums/images/avatars/gallery/simpsons12.jpg)
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Tue Jul 26, 2005 8:34 pm Post subject: |
shaung5 wrote: |
ps, i posted a message last night about the 5.2.02 update, I am using a mac and cannot run the installer, quizface replied with the answer 'Just copy and overwrite the files' is this so ?
Yes you can do this I renamed the files to their origonal names+old.
Surley you have already got the update instaled tho otherwise the apps wont work. |
Posted: Tue Jul 26, 2005 8:41 pm Post subject: |
bigyun2000 wrote: | Thanks Jim-Bob
Yes thats fine. Your a star. |
No need to thank me ScaredyCat is the one who did all the hard work. |
shaung5 Occasional Visitor
Posted: Tue Jul 26, 2005 9:40 pm Post subject: |
Jim-Bob wrote: |
well yes they did work ok but i have changed to the new version 5.2.02 and all is well.
thanks for your patience and help.
shaun |
Posted: Tue Jul 26, 2005 9:51 pm Post subject: |
Thanks also to ScaredyCat.
Excellent stuff _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
Posted: Wed Jul 27, 2005 12:26 am Post subject: |
AH
Here's a thought. If you hit the Quick Add Camera and store a camera.
What if you hit it accidently. Is it possible to remove an entry?
Thanks _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
ScaredyCat Regular Visitor
![](modules/Forums/images/avatars/125678773042e69bbe04bf2.gif)
Posted: Wed Jul 27, 2005 2:02 am Post subject: |
bigyun2000 wrote: | AH
Thanks |
Yes, Just delete it like any other poi. Select change prefs, then move to the manage poi icon, and select delete poi. Type MyCameras in the input box, and select it. You'll then get a list of poi in the MyCameras group. Select the one you want to delete...
SC |
Posted: Wed Jul 27, 2005 9:06 pm Post subject: |
THANKS ScaredyCat
Doohhaa
Never thopught of that. Don't think i've used that before.
Again Thanks ![Embarassed](modules/Forums/images/smiles/icon_redface.gif) _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
fatmanscoop Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_005.gif)
Joined: Jul 07, 2005 Posts: 244 Location: Nottingham...
Posted: Sat Jul 30, 2005 1:41 am Post subject: |
Scaredy cat your the man what cracking stuff |
Posted: Sat Jul 30, 2005 4:30 pm Post subject: |
Updated Autoswitcher released
SC |
DeeSee Lifetime Member
Posted: Sat Jul 30, 2005 5:43 pm Post subject: |
Scaredycat
Have looked at your site and there doesn't appear to be a new fix to pick up (since 24 July).
Has it been put there yet or could it be the cache on my ISP's servers.
Could you also indicate what the update covers?
DeeSee |
Posted: Sat Jul 30, 2005 6:34 pm Post subject: |
This version of autoswitcher differs from previous releases in the following ways:
1. Sleeps for 15 minutes before each check, so accuracy is going to be +16 minutes or less
2. Autoswitcher must ONLY be run from cleanup.txt
3. The start and stop icons don't actually start and stop Autoswitcher, they simply put it to sleep/wake it up.
If you don;t want to run it, remove it from cleanup.txt.
Because Autoswitcher only wakes up in 15 minute intervals, you may not instantly see the messages telling you that it's either paused or restarting.
You may have to wait for a maximum of 15 minutes to see the messages. Autoswitcher could be set to check every second but this would simply use cpu and battery. I could move the message to the trigger apps, but I assumed people would prefer to know when it's actually happened...
What's changed?
In order to eliminate issues of locked up Go's when runing an already running application I've changed the mechanism so that you only create signal's for the running application, you don't actually start it and stop it.
SC |
mazza Occasional Visitor
![](modules/Forums/images/avatars/134748093342c2808ea0bc2.gif)
Posted: Sat Jul 30, 2005 10:47 pm Post subject: |
Thanks ScaredyCat. Great apps.
I just have a problem with the "What time is it" option. When I press it the time is an hour out, even when I try setting the timezone to various other times.
Any idea? |
entwood Regular Visitor
Posted: Sun Jul 31, 2005 10:47 pm Post subject: |
@ Scaredycat
Hi .. I'm very new to this so please forgive any misdemeanors .....
Fantastic set of stuff for the tomtom700 ...well impressed .. thanks ...
I do have one small query ... using the "navigate to lat/lon" beta from the link on the first page ... I've sussed that - means west, + means east and that default (no sign) gives eastings... so I can enter an accurate easting eg 1.21.45, however if I want an westing the most I can input is -1.21.5 and for northings the same limit applies 51.23.6 .. it seems to be limited to 7 digits (including decimal point), such that you can only go to 1/10 of a second ... which is a pretty big "lump" ... now I'm probably doing something totally stupid ......
So please could you inform me what it is ??? I really would like to use this facility to navigate to an accurate lat/lon
Regards and thanks
Entwood |
CaptainBoo Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_et_012.jpg)
Posted: Tue Aug 02, 2005 3:44 pm Post subject: |
mazza wrote: | Thanks ScaredyCat. Great apps.
Any idea? |
I think that this is due to the Satsync going to sleep for 8 hrs so any changes to the timezone will not be applied until the next sync.
You can correct this quickly by changing the timezone and saving, switch off and then press the reset button. Allow it to power backup and once it has re-acquired the time it will apply the new timezone and you should get the correct 'What time is it'.
For ScaredyCat
In the UK current time is UTC/GMT +1, with the timezone set to +1 the 'What Time is it' app shows the correct time but the clock on the status bar shows UTC/GMT and consequently arrival time for a route is also UTC/GMT. Is there any way of changing this - So status bar time is also same as 'What Time'?
Also if you powerdown the Go with the 'What Time' App running it appears to freeze on next startup - I presume this pobably due to the app running at the time but would it be possible to reduce length of time it displays the time/date for? Only a minor niggle if at all but they are great apps. and otherwise work flawlessly on my TTG500. Great work. :D |
