daddyo Occasional Visitor
Posted: Wed Jul 27, 2005 12:56 am Post subject: Safety Camera Icons |
Just installed the zoned Gatso and mobile camera .ov2 and .bmp files along with the specs, redlight and temp .ov2, .bmp files on my TTG700.
I live in liverpool and the vast majority of the camera sites show as the "normal" camera icon with no speed limit information.
Dotted around the place are the odd 30, 50 and 60 icons for a few of the remaing sites.
Is this normal? or should most of the camera sites be zoned and hence show as the speed limit icons rather thatn the normal, standard camera icon? |
Oldboy Pocket GPS Moderator
Posted: Wed Jul 27, 2005 7:52 am Post subject: |
If they are Gatso cameras, it's because nobody has sent the information in for the database to be amended.
The Mobile cameras all have the same icon if you use the standard BMP. The alternative set of BMPs show a speed indication. _________________ Richard
Posted: Wed Jul 27, 2005 10:09 am Post subject: |
Thanks for reply - I was thinking along those lines - just thought I'd check.
What I described in terms of the files on my system is not quite correct however. (sorry - but i've installed and uninstalled so much I got confused!)
initially I installed just the non zoned gatso and mobile files and as expected the non zoned icons were all present.
I then removed the single gatso and mobile files and replaced them with the zoned versions but many of the gatso icons, which were present, were now not on the map - just the odd 30, 50, 60 gatso camera icons.
The only way to get all the gatso icons back, was to put back the gatso and mobile non zoned files along with the zoned ones. I now have mainly non zoned gatso icons and the odd 30, 50 60 icons.
If this is because, as you stated in your reply, that many of the gatso locations have no speed limit information and there fore are not included in the zoned files, that's ok. I just wanted to make sure I was doing everything right.
Thanks again. |
Andy_P Pocket GPS Moderator
Posted: Wed Jul 27, 2005 12:49 pm Post subject: |
Sounds confusing!
Quote: | I then removed the single gatso and mobile files and replaced them with the zoned versions but many of the gatso icons, which were present, were now not on the map - just the odd 30, 50, 60 gatso camera icons. |
What this sounds like, is maybe you haven't installed the "pocketgps_uk_gatso_tba.ov2" (tba=to be announced) set from the speed zoned folder of the download.
As far as I know , the total number of cameras in the "overall" set should be the same as are in the 20,30,40,50,60,70 and tba sets
If some cameras are not showing on the map, you could also double check that all your icon files (pocketgps_uk_gatso_tba.bmp etc.) are present and their names match the .ov2 files names. Do this in Windows Explorer with the Go connected to the PC.
Finally could you tell us the location of a couple of the camera positions that you are having trouble with, so others can have a look on their systems? |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Wed Jul 27, 2005 4:04 pm Post subject: |
If you knoe the speed limits for these cams send them in along with the cam number (name of the POI) to Cameras@PocketGPSWorld.com |
Posted: Wed Jul 27, 2005 5:01 pm Post subject: |
Thanks again for the help.
I'll check the files again when I get home this evening to make sure.
Can't remeber 100% about the tba file being present and this could be my error.
If this solves my problem, it means a lot of cameras in my area are not yet assigned to a limit and so exist in the TBA file (unless i've misunderstood). |
Posted: Wed Jul 27, 2005 7:58 pm Post subject: |
Ok, i've checked things out, all the files are on the TTG ok including the tba files, its just that a lot of the camera locations are not zoned because the vast majority of them in my area are in the tba files i.e. when I remove the tba file, they all dissppear!
I'll get submitting the zoned information for my local camera sites ASAP.
Just a quick one to finish, when should we report camera positions that are only slightly out?
I come accross two sites on my way home that are approx 100-200yards out of position on the map? in one direction you get too much warning, in the other not enough!
Thanks again for your help with the camera files - much appreciated. |
Posted: Wed Jul 27, 2005 8:27 pm Post subject: |
Send 'em in with a note saying it is just a position update for Gatso number xxx etc. Just been doing that for Richard today (felt really proud, he'd asked me to double check one for him! ) |
