Pocket GPS World :: View topic - medion ppc150 use tom tom 5
Haz
PostPosted: Mon Jul 25, 2005 9:42 pm    Post subject: medion ppc150 use tom tom 5 Reply with quote
i am having difficulty using tomtom 5 navigaytor on my MDPPC150.
i have installed the software however it says "NO VALID GPS SIGNAL FOUND"
im using settings gps connect : NMEA-0183
Haz
PostPosted: Mon Jul 25, 2005 9:46 pm    Post subject: Re: medion ppc150 use tom tom 5 Reply with quote
with GPS baud 4800
serial cable on COM 1 ( i have an internal antenna on this pocket pc)
anyone help
cheers
skr80
PostPosted: Sat Jul 30, 2005 6:34 pm    Post subject: Reply with quote
I am also having the same problem - did you sort it?
shaun_uk
PostPosted: Sun Jul 31, 2005 1:20 pm    Post subject: Reply with quote
any of you have any luck?
shaun_uk
PostPosted: Sun Jul 31, 2005 3:08 pm    Post subject: Reply with quote
mine works ok with the same settings, only thing i cant get working is the signal strength meter.it picks up the sat's but i have no idea how many.
Baffled
PostPosted: Wed Jul 18, 2007 10:21 am    Post subject: Reply with quote
please help... tried to update the firmware and was unsuccessful and now can't get a signal?
Border_Collie
PostPosted: Wed Jul 18, 2007 2:25 pm    Post subject: Reply with quote
Try the Mio 168 settings. Other - NMEA, Baud - 4800, On SP2.
If not try TomTom GPS.
Baffled
PostPosted: Fri Jul 20, 2007 1:03 am    Post subject: Reply with quote
Thanks tried all that and something seems to happen with the SP2 but left to run for over 30 mins but nothing....????????????
Border_Collie
PostPosted: Fri Jul 20, 2007 9:26 am    Post subject: Reply with quote
Some time back some people said they had to wait for up tp 45 minutes for the first fix after installation. The same thing would apply if you hadn't used the device for several days or you moved a long way away from your last position with the unit off.
On the Mio 168 there was a small blue/yellow spinning ircle to indicate it was searching for a signal.
Are you going outside under an unobstructed sky? Indoors on in a car, especially with an athermic windscreen, you may not get a lock.
