transit Occasional Visitor
Joined: Apr 12, 2005 Posts: 11 Location: west midlands
Posted: Wed Jul 20, 2005 4:56 pm Post subject: cant delete ttn3 favourites |
hi guys,i realy nead to delete some of my ttn3 favourites but cant.when i tap and hold on them i get the circle of dots but then they dissapear and it just navigates me to that particuler favourite withoout giving me any options(delete,move,edit etc).is there another way of deleting them(using activesinc maybee)dont realy want to reinstall tom tom3.
thanks ian _________________ tom tom one classic v4 |
Robin2 Lifetime Member
Posted: Wed Jul 20, 2005 5:07 pm Post subject: |
You can't delete them. The less frequently used go down to the bottom of the list, and when you have reached the maximum number (I think it's 50) the ones at the bottom get deleted when you add new ones
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
cliffybc Occasional Visitor
Posted: Wed Jul 20, 2005 5:08 pm Post subject: |
Try Tapping Find (2nd Screen) , then tap Favourite. Tap the favourite you no longer want, then tap Edit Favourite.When you delete the name , the favourite disappears from the list.
Cliff _________________ Ipaq 2210,
Rom 1.10.07
Byestor 512 hi-speed sd,
Kingston 512 cf
Tom Tom 5.0
BT GPS |
Posted: Wed Jul 20, 2005 6:35 pm Post subject: |
cliffybc wrote: | Try Tapping Find (2nd Screen) , then tap Favourite. Tap the favourite you no longer want, then tap Edit Favourite.When you delete the name , the favourite disappears from the list.
Cliff |
hi m8 have tried that but when i tap i get no options at the favourites screen so i cant edit or delete,i just get the circle of dots as i tap and hold but no options it just starts navigating after a couple of seconds to the favourite as if i had just tapped and not held down(which i have)dont realy know what to make of it as its worked in the past? _________________ tom tom one classic v4 |
Posted: Wed Jul 20, 2005 11:25 pm Post subject: |
hi, just to check are you tapping FIND then favourite rather than Navigate To then favourite? I have just tried it again and I have no problem deleting any of my favourites. Incidently I don't have a route set nor my gps unit switched on.I don't know if that will make a difference. When I do the above I get a screen with 6 choices
1.Edit favourite
2.Add as POI
3.Add to itinerary
4.Nearby points of interest
5.Reset gps for this location
6.Set as departure.
Follow my original instructions then confirm you can see this screen.
Regards Cliff[/u][/b] _________________ Ipaq 2210,
Rom 1.10.07
Kingston 512 cf
Tom Tom 5.0
BT GPS |
Posted: Thu Jul 21, 2005 10:28 am Post subject: |
hi cliff
thanks for your help,i was indeed navigating to instead of finding,pretty sure this wasnt the way i used to delete but have followed your instructions and this way works a treat :D
Posted: Thu Jul 21, 2005 11:37 am Post subject: |
No problemo -glad to help
regards Cliff _________________ Ipaq 2210,
Rom 1.10.07
Kingston 512 cf
Tom Tom 5.0
BT GPS |
LiveLifeGoJump Regular Visitor
Posted: Wed Jul 27, 2005 11:37 pm Post subject: |
Can't be sure as I've not got TTN3 on my PPC now but if I remember correctly you switch to favorites then tap & hold on the one you want to delete & a sub menu comes up.
I know I had no probs deleting favorites I had set when I was learning to use it.
Same method was used to delete itenary items. _________________ If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE |
