Pocket GPS World :: View topic - Cant get Winfast's Leadtek navigator program to run!!!!
Andayle
PostPosted: Fri Jul 15, 2005 11:01 am    Post subject: Cant get Winfast's Leadtek navigator program to run!!!! Reply with quote
Hiya all
I have the PNA175 Medion, I have used the UI hack so I have the taskbar etc. Im trying to get Leadtek navigator program running so I can change my GPS values so that TT5 software can read my signal.
I run the install from my desktop with active sync running and it all goes to the device fine. The device flashes up about installing a new app. When I try and run the program I get this message
"Cannot find 'Navigator' (or one of its components). Make sure the path and filename are correct and that all the required libraries are available."
Anyone have any ideas?
Many thanks in advance.
Dean
gimly
PostPosted: Sat Jul 16, 2005 7:02 pm    Post subject: What version Reply with quote
Did you make sure that you downloaded the CE version and what version operating system are you using?
shaunokeefe
PostPosted: Sat Jul 16, 2005 7:07 pm    Post subject: Reply with quote
You need some extra DLL's I think
Mine runs but a) its stuck at the tom of the screen, cant see any menu's
and it just doesnt do anything
Shaun Okeefe
Undernet User-Committee
Webmasters / Translators / Promotions
simba@user-com.undernet.org
Satellite
PostPosted: Tue Jul 19, 2005 3:50 pm    Post subject: Reply with quote
Hi, is this the hardware you use?
http://www.pocketgpsworld.com/reviews/medion-mdpna-150/mdpna150_1.jpg
If so you don't need " Leadtek " just choose the Tom Tom wired gps in the GPS option. I didn't change any other option, you'll get a message saying " GPS not found " give it a bit of time and you should see another message saying " waiting for gps signal " or something like that. That's it you should have the signal bar working after a while.
I thought I had the same problem and, like you I tried Winfast but I was having the same error. Left everything as it was and...bingo it worked.
Have you got the voices working?
If not you have to create a folder called TomTom and put it in the TomTom folder in Windows and then drag the installed voices data files in
your newly created folder.
Good luck
shaunokeefe
PostPosted: Tue Jul 19, 2005 4:09 pm    Post subject: Reply with quote
I have this ........
http://www.vhost.org.il/~simba/medion1.jpg
http://www.vhost.org.il/~simba/medion2.jpg
http://www.vhost.org.il/~simba/medion3.jpg
And its giving me problems :-(
Shaun
Satellite
PostPosted: Tue Jul 19, 2005 4:12 pm    Post subject: Reply with quote
I think is the same.
What kind of problems?
shaunokeefe
PostPosted: Tue Jul 19, 2005 4:15 pm    Post subject: Reply with quote
Well at the first the program wouldnt run at all, so i installed the missing DLL's from the dll pack you can get and it runs now.
But the program is stuck at the top of the screen (So cannot see any menu's and does nothing....trying to get you a shot now)
shaunokeefe
PostPosted: Tue Jul 19, 2005 4:18 pm    Post subject: Reply with quote
here is the shot of what mine looks like
http://www.vhost.org.il/~simba/medion4.jpg
