Muzy Occasional Visitor
Posted: Mon Jul 18, 2005 12:18 pm Post subject: Re: Favour required on XY co-ordinates ! Where in the world. |
[quote="gilbem1"]I have received my French holiday destination GPS co-ordinates from the holiday company, but when I create an ITN (as described in this link) file with them in, they appear in amber with a line through them and the option to <Show on Map> is greyed out.
Could someone who knows how, please check for me where the hell in the world these co-ordinates refer to, as I'm sure the XY details are not in France.
Listed below as per their brochure !
Site 1: X: -151200m Y: 5410000m 43:49:58N 1:21:31W
Site 2: X: 1800m Y: 5946300m 47:13:04N 0:00:57E
Posted: Tue Jul 05, 2005 12:36 am Post subject:
[Quote] simply recalculate the lat/lon values into decimal representation and then multiply by 100000
I have the same problem - but different sites in France! As a complete novice to using lat/long (but not TTN) my question is how do I recalculate the lat/long values into decimal representation?
Apologies if this is a stupid question, but if you don't ask, you'll never learn!
Thanks |
julianbarker Lifetime Member
Posted: Mon Jul 18, 2005 1:27 pm Post subject: |
Simply devide seconds by 60 to get decimal minutes and divide decimal minutes in the same way to get decimal degrees -
N43:49:58
58/60 = 0.9666666667 minutes
49.96666666667/60 = 0.8327777778 degrees so
N43:49:58 = N43.8327777778 in decimal degrees format.
Note I have reduced these to ten decimals - the numbers are much longer than that! |
Posted: Mon Jul 18, 2005 1:45 pm Post subject: |
Now for the next bit - N43.8327777778 IIRC needs to be converted to a decimal of the 90 degrees from the equator to the North Pole -
Divide by 90 and you get 0.48703086419755555555555555555556
Multiply by 100000 and you get 48703.
By convention N and E are positive values S and W are negative. Note that in E and W there are 180 degrees, not 90.
Personally, to avoid all this I would use something like POIEdit that does all the work for you.
If any of this is wrong - please feel free to correct, I am only going from memory. |
Posted: Mon Jul 18, 2005 1:46 pm Post subject: |
Pedro-G Occasional Visitor
Posted: Fri Jul 22, 2005 6:34 am Post subject: |
How about the other way round (compared to the original topic of this thread)?
What would be the most convenient way of finding the coordinates of a given spot on TomTom 5's map, or an address? Would you save it as a favorite, create an itinerary starting from there, or what? And then how to see the coordinates? |
Oldboy Pocket GPS Moderator
Posted: Fri Jul 22, 2005 8:12 am Post subject: |
Pedro-G wrote: | How about the other way round (compared to the original topic of this thread)?
If you create an itinerary and export the file to the PC, you can read the co-ordinates in a Text Editor. Note that there is no decimal point in the Itinerary numbers.
If you create a POI category you can export this to the PC, convert it to a Text File, (use something like Dumpov2) and read the co-ordinates in a Text Editor. _________________ Richard
TT Via 135 App 12.075: Europe Map v1140 |
barryd Frequent Visitor
Joined: Mar 27, 2004 Posts: 285 Location: Cheshire, England
ncsl Occasional Visitor
Posted: Tue Aug 09, 2005 12:51 pm Post subject: Saving Lat/Lon as you go along |
Is there a way using TT Nav 5 with HP IPAQ to save as POI any current positions.
I would like to save POI or Lat/ Lon as I travel along on rivers and esteuries so I can reuse these on the return journey?
Thanks |
Posted: Tue Aug 09, 2005 7:04 pm Post subject: Re: Saving Lat/Lon as you go along |
ncsl wrote: | Is there a way using TT Nav 5 with HP IPAQ to save as POI any current positions.
Thanks |
There's probably another way, but here goes.
Browse Map/Tap Arrow at top of screen/Navigate Icon/Add as POI.
The Arrow sets your current position to the centre of screen (flashing cursor) and the Navigate Icon (cursor icon) gives options to do something at the cursor point. _________________ Richard
hyjacks Occasional Visitor
Posted: Sat Aug 20, 2005 1:30 am Post subject: |
thank you very much i was wondering how to do this with tt5. this program makes it very easy yipeeeeeeeeeeeeeeee save me loads of time. |
SparksSailor Occasional Visitor
Posted: Fri Sep 23, 2005 9:25 pm Post subject: Remove OS GPS |
How can I complete remove OS GPS Converter from the PDA? |
Posted: Fri Sep 23, 2005 10:12 pm Post subject: |
Hi there
To remove it, simply delete whichever files you installed. The following list shows all files you may have installed and any other files it may have created:
- OS GPS Convertor.exe program file
- Shortcut to the program file
- osgps.ov2 and osgps.bmp files in the TomTom map folder
- osgps.itn file in the TomTom itinerary folder
- osgps.dat and osgps.bmp files in the Destinator favorites folder
- apidata1.$$$ file in the OziExplorer program folder
It saves your option settings and the last position entered in the registry. Should you want to delete them (personally I wouldn't bother, they'll do no harm left there and take up very little space) you'll find them in:
HKEY_CURRENT_USER\Software\OS GPS Convertor
Hope this helps _________________ Barry Davies
freddan Occasional Visitor
Posted: Fri Sep 30, 2005 2:59 pm Post subject: |
newbie here....
I made a new ITN-file with coordinats. When I open it up in TT5 I have a red line crossing my new entry and I cannot do "Show on map".
I´m doing something wrong here....
//F |
Posted: Fri Sep 30, 2005 6:50 pm Post subject: |
Hi freddan
The red line indicates that this position is not within the area covered by the map currently loaded in TomTom. So you need to either load a map for that area, or check your coordinates as they may not have been entered correctly.
Assuming you're using my utility, by all means post an example of a position you want to enter and how you're doing it, and I'll try to be more help.
Best wishes _________________ Barry Davies
Posted: Mon Oct 03, 2005 12:18 pm Post subject: |
Thanks for your reply.
No I´m not using your app.....live in Sweden.
I´ll check everything one more time to see whats up...
/Freddan |
