Pocket GPS World :: View topic - Problem reading maps on memory card
towny
Banned
PostPosted: Fri Jul 15, 2005 3:08 pm    Post subject: Problem reading maps on memory card Reply with quote
Hi, sorry if this has been posted before but can anyone help me. I have a Medion md95900 with a 512mb SD card installed, when i add more than one set of maps to the card it will only read one of them using navigator either UK or France (Usually France as F is before U in the alphabet)) but not both when selecting the map. Both maps are on the card as i can access both maps seperatly if i alter the folder names (EG maps is changed to 1maps) then the device only reads the one with the correct name. Sorry if this sound confusing but not sure how else to decribe it.
towny
tel33
PostPosted: Fri Jul 15, 2005 5:08 pm    Post subject: Reply with quote
Sorry I am confused!
Are you saying you cant access both maps at the same time?
You can only access one map at a time so is this what you mean?
tel33
IPAQ 3950 Tomtom 6 with Navman 3450 sleeve v6 USA & Canada & Western Europe maps, 2gb Sandisk sd card, POIWarner V2.0.
TomTom 920T, v715 maps for USA & Canada, Western & Central Europe, 4gb SDHC Transcend Class 6
towny
Banned
PostPosted: Fri Jul 15, 2005 7:09 pm    Post subject: Reply with quote
Sorry about that i know i wasnt very clear. I can install both uk and France street maps on the memorycard when i try and access them (in navigator) all i can see is one set ofmaps usually France, if i modify the folder names then i can see the UK map. They will not apear in the map list togeth so i can not switch between them. I am not trying to use them together just cant see both sets of maps.
Thanks for a quick reply
towny
tel33
PostPosted: Fri Jul 15, 2005 7:38 pm    Post subject: Reply with quote
Ok I think I get it now.
You have two maps on the SD card, France and the UK
When you try to change maps you only get one map showing e.g France as its further up the alphabet.
But if you change the the folder names of the maps them you can see them but cant gain access to them.
If I have this correct you have one folder with two foldwers inside it with the seprate maps in each folder.
Ok what you need to do is to make a seperate folder for each map and do not put them in the same main folder e.g It should look like this.
France folder has France map in and UK folder has UK map in.
With any luck this should solve the problem I hope! Confused
towny
Banned
PostPosted: Fri Jul 15, 2005 8:27 pm    Post subject: Reply with quote
They are in 2 seperate folders, what i meant by changing the name is france has its own folder and UK has its own folder,
they both have a sub folder called maps which is the folder containing the data. Now it always only opens the France folder as F is before U in the alphabet so if i call the France map folder 1map navigator doesnt see it and looks at the UK map folder instead and i can get to the maps but i can not see both folders in navigator,
I have hard reset and soft reset i have reinstalled both maps (just in case) twice but it just wont see both maps in navigator so i am a bit stumped.
towny
tel33
PostPosted: Fri Jul 15, 2005 9:35 pm    Post subject: Reply with quote
What version of Medion Nav are you running?
towny
Banned
PostPosted: Fri Jul 15, 2005 9:54 pm    Post subject: Reply with quote
I'm running 4.75 the maps are 4.4
towny
Stumartin
PostPosted: Fri Jul 15, 2005 10:12 pm    Post subject: Reply with quote
I have the same problem !!
Just that when I pull all of the maps onto a 1gig card and insert it into my MD95900 it changes all the files into Gobbldygoop
(Unuesable) if i put 1 map on to the card its ok
More than one it seems to refuse
I have formatted the card
I have tried putting all the maps intop one folder :x called maps and also seperat IE france ;germany ;benelux:to no avail
any ideas ?????
Stu
View user's profile Send private message AIM Address
Stumartin
PostPosted: Fri Jul 15, 2005 10:13 pm    Post subject: Reply with quote
any ideas ?????
Stu
tel33
PostPosted: Fri Jul 15, 2005 10:45 pm    Post subject: Reply with quote
Hmmm strange Confused
It seems as though there are some SD cards that are not compatible, they seem mostly to be Kingston ones.
Which make of SD cards do you both have?
Have a look around on the forum to see about the incompatability problems.
I will see if I can figure out what your problem is anyway.
Regards
tel33
Stumartin
PostPosted: Fri Jul 15, 2005 11:27 pm    Post subject: Reply with quote
OOPS
Its a 1 gig MMC card---firm TAKEMMC CARD
Stú
Pocketgps
PostPosted: Sat Jul 16, 2005 12:32 am    Post subject: Reply with quote
You have to select the map from the menu
Stumartin
PostPosted: Sat Jul 16, 2005 4:25 am    Post subject: Reply with quote
Thanks for your helping hand :P
It does not get as far as that like I say if I put more than one map set on the card it seems to corrupt all the files
If I only put on one map it is ok !
I was driving myself up the wall last weekend .trying every way to do it
I even used the win2000 disk check it found no probs
I darnt buy another card incase it is the same
Stu
towny
Banned
PostPosted: Sat Jul 16, 2005 5:22 am    Post subject: Reply with quote
Thankyou pocketgps and tell33, Select map, thats it problem solved......note to self ALWAYS READ THE MANUAL.
As to memory i have no problems at all, i got mine from
www.mymemory.co.uk a 512mb card is only £17.99
and 1gig about £44 for there own brand.
towny
Pocketgps
PostPosted: Sat Jul 16, 2005 1:44 pm    Post subject: Reply with quote
Stu
If you have been using a card reader then that may be the problem, for some reason depending on the make of card reader all the files transfer to the card OK, you can see them on your main PC but when the card is in the PDA it will not see them, copy the files that you cannot see from the card to a folder on your main PC, then this is the boring bit, now connect your PDA via ActiveSync and then copy and paste them to the storage card, that takes for ever I Know, but it usually works.
22.101 (03 Oct 24)
