Pocket GPS World :: View topic - ttn3 and ipaq 4700
ttn3 and ipaq 4700
jasb
PostPosted: Fri Jul 15, 2005 2:31 pm    Post subject: ttn3 and ipaq 4700 Reply with quote
Hello
I know there are a lot of people complaing about ttn5 and the 4700(memory drain/freezing etc..) .Does this also happen when using tt3?
thanks
jasb
jasb
PostPosted: Fri Jul 15, 2005 3:10 pm    Post subject: Reply with quote
Thanks Alan :D
chrisnel
PostPosted: Fri Jul 15, 2005 5:01 pm    Post subject: Reply with quote
Am seriously considering re-installing TTN3 until these probelms with TTN5 sorted.
TomTom GO 730
jasb
PostPosted: Fri Jul 15, 2005 5:09 pm    Post subject: Reply with quote
You were not having any problems with tt3 then?
Crazy way to run a business!? eh..
Stop it! jasb
chrisnel
PostPosted: Fri Jul 15, 2005 5:20 pm    Post subject: Reply with quote
Yes, my previous set up worked fine for the six months I used it. TTN5 is great when it works and some of the enhancements made are good, e.g. ability to switch traffic updates on and off easily, full postcode search.
My problem with TTN5 is it keeps freezing. And for some reason when exting it switches off my Bluetooth settings.
TomTom GO 730
Burn1
PostPosted: Fri Jul 15, 2005 7:20 pm    Post subject: Reply with quote
Have had the same problem since upgrading to tt5. Went back to tt3 last week and have been happy ever since. However the memory leak still continues since installing the new ROM (1.1) and also have had connectivity problems with WiFi. I will be reinstalling the previous ROM version tomorrow and hope all works as before. "IF IT AINT BROKE, DON'T FIX IT"
PostPosted: Fri Jul 15, 2005 8:12 pm    Post subject: Reply with quote
I to have had no problems with TT3 and 4700 unit, it works fine with either Bluetooth or wired GPS but TT5 is useless - I do use it on my XDAIIs where vs5 is the only one that will work so its not all bad - just wait till they sort out the vs5 before you put it on the 4700 - at the price they are charging fo it - it should load and work without any problems on a unit still considered top of the range from HP - the fact that it won't work with any VGA equipped PDA must be causing TT to re-code fairly quickly - (the sooner the better) - Mike
jasb
PostPosted: Sat Jul 16, 2005 4:51 am    Post subject: Reply with quote
Thanks for all the quick replies!, very usefull
Burn1 could you let me know if you still get the memory leak when you go back to 1.0
I'd narrowed my choice of pda's down to the dell axim 50v and the 4700.Soon discounted the dell when i found out about the very short battery life.Just one more question,reading the specs of the 4700 i see that it has 55mb of ram and 80 mb of flash rom...does this mean i could load tt3 on to the 80 mb flash memory (with maps on a cf card)leaving the 55mb of ram to run the program?
jasb
Burn1
PostPosted: Sat Jul 16, 2005 11:35 am    Post subject: Reply with quote
jasb
Jasb, went back to previous ROM and NO memory leak. Took about two hours to reload apps. and tt3, all works without a hitch, so it looks like there is a problem with the new iPAC ROM. Your assumption above is correct. TT3 maps (about 110meg) are stored on sd or cf card so leaves you loads of space on device. I would say I am very happy with the 4700 just a bad experiance with tt5 and new ROM. Will have to sit around 'till developers have finished their beta testing on other users and then upgrade. Good luck with whatever you decide on.
jasb
PostPosted: Sat Jul 16, 2005 1:10 pm    Post subject: Reply with quote
Thanks Burn1 looks like pc world will be getting my money for a 4700 after all :D
Glad your setup is working ok now. If your anything like me ..this sort of thing drives me through the roof!
Thanks again to everyone for their help
jasb
