ferjan Occasional Visitor
Posted: Sat Jul 09, 2005 6:51 pm Post subject: Sd or MMC card for Medion 95900 |
Does the Medion 95900 use SD and MMC memory cards, cos I got a SD card but when I try and use it, it says not reconised and I can not run anything from it...still its' handy for the wifes digi camera m, my lose her gain hi.
If it only uses MMC cards where is the best place to obtain one please, I want to make sure I get the right one.
Thanks. :P |
neil01 Frequent Visitor
Posted: Sat Jul 09, 2005 9:03 pm Post subject: |
I don't know for certain about MMC cards and CoPilot, but it SHOULD work with SD cards.
If it isn't working with the SD card, sounds like a problem with the card or the reader. |
Posted: Sun Jul 10, 2005 6:07 am Post subject: Thanks |
Thanks for the reply Neil01...well I installed the software from the cd via Active sync and also via exployer to the Sd card and both ways it had the same result, can not reconise the SD card, doing a soft restart but then nothing happens after that.
I also copied everything from my original card and installed that but just the same result yet the card works fine in my camera.
When I check on the card I can see everything which should be on there but it just wont run should I get a different card??
The card I have is a Kingston SD card 512 mb
Cheers |
itxweather Occasional Visitor
Posted: Mon Jul 11, 2005 12:46 am Post subject: Re: Thanks |
ferjan wrote: | Thanks for the reply Neil01...well I installed the software from the cd via Active sync and also via exployer to the Sd card and both ways it had the same result, can not reconise the SD card, doing a soft restart but then nothing happens after that.
Cheers |
Hi Ferjan,
Have found a 256Mb and 512Mb SD card to work alright containing MP3 but cannot make a working back-up of softward running on 256Mb SD card either :-(.
Does anyone have any ideas?.
Thank you.
Best Regards. _________________ itx-weather.co.uk
http://www.itx-weather.co.uk |
Posted: Mon Jul 11, 2005 1:37 am Post subject: Re: Thanks |
Cheers |
Hi ferjan,
Just this minute found that the 95900 does not like Kingston SD cards. Copied the back-up files from the Installation folder and finally a working back-up. Medion Navigator installs successfully (but not using a Kingston 256Mb or 512Mb SD card).
Cannot understand why Kingston SD cards won't work, particularly as the installation files have copied across successfully via ActiveSync and Explorer method suggested in the Readme.txt file on CD1.
Perhaps something to to with working voltage?. Really don't know.
Posted: Mon Jul 11, 2005 10:13 am Post subject: SD card problem |
Thanks for the reply's to the SD card problem..glad it's not just me having trouble with the Kingston SD card.
I see on my card the voltage is set for 3.3 volts weather the other cards a different I don't know.
So now the question of what to buy...I have seen Sandisk, Lexar and Transcend all available.....BUT WHICH ONE WILL WORK !!! I don't want to keep buying them and them ending up in the wifes camera hi...maybe I should go for a MMC card instead??? if anyone has bought a new card and got it working ok then please reply...
Cheers 8) |
Posted: Mon Jul 11, 2005 6:28 pm Post subject: Re: SD card problem |
ferjan wrote: | Thanks for the reply's to the SD card problem..glad it's not just me having trouble with the Kingston SD card.
Cheers 8) |
Hi Ferjan,
Just sent you a PM, basically confirming that i'd used a Sandisk SD Card last night after failing dismally to get a 256Mb and 512Mb Kingston SD Card to work.
Posted: Tue Jul 12, 2005 6:01 pm Post subject: |
I have a Mio 168 and use a Maxell 256 MB card (from PC World) |
tel33 Regular Visitor
Joined: Mar 23, 2005 Posts: 159 Location: UK Portsmouth
Posted: Tue Jul 12, 2005 10:40 pm Post subject: |
I have a Corsair 1gb SD Flash Media 40x card and have no problems. _________________ IPAQ 3950 Tomtom 6 with Navman 3450 sleeve v6 USA & Canada & Western Europe maps, 2gb Sandisk sd card, POIWarner V2.0.
TomTom 920T, v715 maps for USA & Canada, Western & Central Europe, 4gb SDHC Transcend Class 6 |
Posted: Thu Jul 14, 2005 10:52 am Post subject: |
tel33 wrote: | I have a Corsair 1gb SD Flash Media 40x card and have no problems. |
Sorry for being a bit 'off-topic', but do you find that you notice any differences when using the faster card? Although mine works - I wouldn't exactly describe it as fast! |
shaun_uk Occasional Visitor
Posted: Thu Jul 14, 2005 2:29 pm Post subject: |
also of topicish what is the maximum size card these will take, i was going to get a 1 gig mmc card for mine but have just noticed you can get a 2 gig now (will be great for watching films on) :D (im not sure if there is a limit like they is on some mobile phones) cheers for any help |
Posted: Thu Jul 14, 2005 4:45 pm Post subject: |
In answer to your question about if I think the 40x SD card being faster makes the unit faster, I personally feel there is an improvement in repsonse times over the medion supplied one but not much to make a tremendous difference.
I know there are faster SD cards out there (133x!!) so maybe like most memory which is normally the major bottleneck in any computer system, as the SD memory cards improve so will the units response until it eventually nearly the speed of the CPU and reduces the bottleneck but when that will happen I dont know.
As for my 40x card I just bought it as it was a good price.
Regards
tel33 _________________ IPAQ 3950 Tomtom 6 with Navman 3450 sleeve v6 USA & Canada & Western Europe maps, 2gb Sandisk sd card, POIWarner V2.0.
