njay Occasional Visitor
Joined: 02/09/2003 14:28:29 Posts: 7 Location: United Kingdom
Posted: Tue Jun 28, 2005 6:29 pm Post subject: TTN5/iPAQhx4700/Global Sat BT-338 connection problems. |
Help!!!!
Have tried all the remedies on the forum for connecting my new BT-338 to TTN5 (38400 baud rate, other wired etc) but all to no avail. The GPS and 4700 are paired correctly and when TTN5 is started, the blue light flashes quickly and the green light flashes as well. When you go back to TTN5 the screen shows no GPS device. I have an iPAQ 3870 running TTN3 and the 338 happily connects. Also I have had lengthy emails with TT support but they still have no answer to the problem. Any ideas? |
SimonCatlin Frequent Visitor
Posted: Tue Jun 28, 2005 7:54 pm Post subject: |
Try ingnoring the Other BT Device and select Serial device and then enter the Com port and Baud rate that the BT-338 is talking the IPAQ on. _________________ iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk) |
Posted: Tue Jun 28, 2005 8:05 pm Post subject: |
Spudson Regular Visitor
Posted: Wed Jun 29, 2005 11:45 am Post subject: |
Simon,
If you're watching this thread, any chance of a response to my PM?
S |
FLYINGSCOT Occasional Visitor
Posted: Wed Jun 29, 2005 7:29 pm Post subject: try this |
hi
i been having the same problem on the com port side
tried everything (look at my posts)
just tried taking a major step back with tom tom gps drivers and it worked im now connected
stepped back to v1.35 and com port 8 became available for me
worth a try
here is link to get drivers
http://www.griffinnet.co.uk/downloads.htm |
Gando Occasional Visitor
Posted: Sat Jul 02, 2005 10:19 pm Post subject: |
I have the same equipment and none of the things I tried worked until I removed the battery from the bt338 for 2 minutes then after restarting it like magic everything worked - so its worth a try |
chameleon Occasional Visitor
Posted: Sun Jul 03, 2005 5:29 pm Post subject: |
Gando wrote: | I have the same equipment and none of the things I tried worked until I removed the battery from the bt338 for 2 minutes then after restarting it like magic everything worked - so its worth a try |
Quote: | thanks Gando it worked for me to after remving the battary from the bt318, com port 8 appearde in tt5. Great! chameleon |
Posted: Sun Jul 03, 2005 5:30 pm Post subject: |
Quote: | thanks Gando it worked for me too after removing the battery from the bt318, com port 8 appeard in tt5. Great! chameleon |
BarrieG Occasional Visitor
Posted: Thu Jul 07, 2005 1:10 pm Post subject: |
chameleon wrote: | Gando wrote: | I have the same equipment and none of the things I tried worked until I removed the battery from the bt338 for 2 minutes then after restarting it like magic everything worked - so its worth a try |
thanks guys - this also worked for me too! Rgds
BarrieG _________________ Thanks
BarrieG |
Posted: Tue Jul 12, 2005 8:29 pm Post subject: BT-338/hx4700/TTN5 |
Thanks it worked!!!! Now all I have to solve is the VGA memory leak system! |
Posted: Tue Jul 12, 2005 8:30 pm Post subject: BT-338/hx4700/TTN5 |
Taa
njay |
