Pocket GPS World :: View topic - got tt5 running on medion
whatabody
PostPosted: Mon Jul 11, 2005 6:22 pm    Post subject: got tt5 running on medion Reply with quote
ive got it working perfect apart from 2 things voices and it wont show me howmany sats ive got but when i use it everything else seems to work can anyone tell me how to sort these 2 problems out sorting the voices is a must all i need to no is where to place the voice files as i did somthing before and it got german and lux working but not the english voices so i know it must be possible cheers
whatabody
PostPosted: Mon Jul 11, 2005 6:33 pm    Post subject: ps Reply with quote
mine is the 175 from halfords
whatabody
PostPosted: Mon Jul 11, 2005 11:52 pm    Post subject: sorted Reply with quote
ive now got voices working after alot of messing so 1 down 1 to go
just to sort the gps bars now
shaunokeefe
PostPosted: Thu Jul 14, 2005 6:35 pm    Post subject: Reply with quote
Hay mate,
Im a newbie when it comes to sat nav stuff so few questions :-)
I purchased the medion navigator from aldi in the UK and its running 4.75 version software.
Are you saying I can nuke this totaly and turn this into a tomtom version 5?
If so would you be prapared to show me how to do it, only reason i purchased this was because I couldnt afford the tomtom
Many thanks
Shaun Okeefe
tel33
PostPosted: Thu Jul 14, 2005 7:11 pm    Post subject: Reply with quote
Maybe this post may help you along the way with your problems?
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=30298
tel33
IPAQ 3950 Tomtom 6 with Navman 3450 sleeve v6 USA & Canada & Western Europe maps, 2gb Sandisk sd card, POIWarner V2.0.
TomTom 920T, v715 maps for USA & Canada, Western & Central Europe, 4gb SDHC Transcend Class 6
shaunokeefe
PostPosted: Thu Jul 14, 2005 7:23 pm    Post subject: Reply with quote
Yes this is a dam good site,
However it says "Installed the new tomtom software"
Whats it called? and where can i get it......emule / bittorrent ?
Shaun
fartyass
PostPosted: Thu Jul 14, 2005 7:32 pm    Post subject: Reply with quote
Hi I also have a Medion 406000 & have recently installed tomtom 5.Everything works BUT I to have problems with the display showing no sat signals being recieved.I have a fealing its the driver for the Royal tek ? gps mouse in tt5 being the problem.I have tried useing the on board nimea setting & also the tt gps mouse setting.Both will work but not display the sat sigs ANY IDEAS?
Everything worked fine on installing tt5 on my medion 90500 (mitac 168 clone)
Another question ,I have installed Yoda & Darth Vada voices are there any other freeby voices out there?
Also is there anlernative the stupid bells beaps to use when announcing the poi,s
shaunokeefe
PostPosted: Thu Jul 14, 2005 7:36 pm    Post subject: Reply with quote
Where did you get your TTN5 software ?
Need that so I can at least try and install it Laughing Out Loud
shaun_uk
PostPosted: Thu Jul 14, 2005 8:20 pm    Post subject: Reply with quote
check your PM Smile
Navigotmee
PostPosted: Thu Jul 14, 2005 10:23 pm    Post subject: Reply with quote
Can you also tell me the best place to buy TT5, have had enough of Navigon.
Regards
Navigotmee
fartyass
PostPosted: Thu Jul 14, 2005 10:43 pm    Post subject: Reply with quote
Doh ! Should have checked the forum more fully before I posted.Please cue here to kick my but. Laughing
Originally posted by Phil 4242
I had a similar problem with my PPC250 (before it was stolen ) when I went from the Medion-supplied GPS application to Navigon Mobilie Navigator 4.2.
I used Leadtek's 'GPS Monitor' application (available on this site from the 'Downloads' section, if I remember correctly), to change the messages sent by the Royaltek GPS.
If you get the application 'talking' to the GPS and then go 'Tools - Command - NMEA', you'll be able to change what messages are sent , and how often.
I found the following to work OK:-
GGA 1 VTG 1
GLL 2 MSS 2
GSA 5
GSV 5
RMC 1
with all the User entries as 0.
Hit OK, completely exit and kill GPS Monitor, start you normal GPS application and see if you get the display you expect.
Getting older and more senile by the minute !
Philip
Downloaded the application here http://www.pocketgpsworld.com/modules.php?name=Downloads&d_op=viewdownload&cid=8
You are looking for the ce version.Download the application & active synch it to the Medion pda Start the application (be patiant) & you should get the programme talking to the gps antena.The settings suggested by Phil 4242 were spot on.
Exit the application & start tt5.Bingo sat signals being recieved on display screen of tt5.
I would like to thank phill 4242 for his post.
Hows the but kicking que looking Laughing
shaunokeefe
PostPosted: Fri Jul 15, 2005 9:40 am    Post subject: Reply with quote
Having problems installing the thing,
I unzip all the cab files and when it comes to the ttn.cab i click on it and it points to the DIR to install it to then bombs out.
all the other cab files were ok , wzd.cab, gps.cab , PIMAddin.cab
Any clues?
philip4242
PostPosted: Fri Jul 15, 2005 10:43 pm    Post subject: Reply with quote
Thanks for the thanks !
Time to make my original post a 'sticky', mods ?
Philip
Navigotmee
PostPosted: Sat Jul 16, 2005 1:02 am    Post subject: Reply with quote
check your PM Smile
Please any help.
Navigotmee
shaunokeefe
PostPosted: Sat Jul 16, 2005 12:27 pm    Post subject: Reply with quote
Problem is,
I've downloaded 3 different tomtom navigator 5's now and none of them work on my medion.
Here's the exact model of mine.
MD95900 MDPNA 200S
22.063 (19 Jun 24)
