Pocket GPS World :: View topic - ICN 610 help
ICN 610 help
herc
PostPosted: Mon Jul 11, 2005 9:02 am    Post subject: ICN 610 help Reply with quote
A friend at work has recently purchased the navman 610 how do I add speed camera alerts for her>?
Also should I update her software if so where should I download these from.
Thnx in advance.
Tim Buxton
PostPosted: Mon Jul 11, 2005 9:08 am    Post subject: Re: ICN 610 help Reply with quote
Thnx in advance.
Instructions for loading the SC database are here and the downloads page for installing service packs is here.
Tim
herc
PostPosted: Tue Jul 12, 2005 9:20 am    Post subject: Reply with quote
Tim I get the message after follwing your instructions saying no poi's to manage is this correct??
herc
PostPosted: Tue Jul 12, 2005 9:38 am    Post subject: Reply with quote
herc wrote:
Tim I get the message after following your instructions saying NO poi's found in input file
Tim Buxton
PostPosted: Tue Jul 12, 2005 9:53 am    Post subject: Reply with quote
I'm a bit puzzled. Which instructions have you followed? Have you actually transferred anything onto your 610? The 'No POIs to manage indicates that you have not, to me.
Tim
herc
PostPosted: Tue Jul 12, 2005 8:56 pm    Post subject: Reply with quote
Is there a way of checking what has gone across to the sd card on the navman.
I used the send to device command.
Tim Buxton
PostPosted: Tue Jul 12, 2005 9:37 pm    Post subject: Reply with quote
The 6xx series stores Custom POIs in Internal Memory, I think, not on the SD/MMC card. Any Custom POIs which are present will show in the MYPOI category if you've enabled it, and will be 'Manageable' by the POIEditor.
Tim
SANDMANBLACK
PostPosted: Wed Jul 13, 2005 7:15 pm    Post subject: Reply with quote
i had 2 take sd card out 2 load my speed camera locations,worked tidy then
droseman
PostPosted: Fri Aug 05, 2005 6:09 pm    Post subject: Reply with quote
I read in the user manual for my 610 that you can only store 25 Custom POIs - if this is the case, surely that would make installing the speed camera database impossible?
icsys
PostPosted: Fri Aug 05, 2005 6:43 pm    Post subject: Reply with quote
That is 25 custom POI groups of which safety cameras is one group.
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
droseman
PostPosted: Sat Aug 06, 2005 9:08 pm    Post subject: Reply with quote
ok, that makes sense. Thanks Smile
icsys
PostPosted: Sun Aug 07, 2005 1:46 pm    Post subject: Reply with quote
In addition to the above, and to clarify a little more, if you install the single 'all camera' file it is one POI.
Installing all of the speed zoned camera files in order to have seperate icons for each speed, will take up 14 POI groups.
HTH
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
22.071 (03 Jul 24)
