Pocket GPS World :: View topic - Permanent Supply to Wired GPS
Tommy3090
PostPosted: Sun Jul 10, 2005 10:49 pm    Post subject: Permanent Supply to Wired GPS Reply with quote
I've just finished hardwiring my TT5 into my car.
Now that I have, will I be doing my wired receiver any harm
having a supply 24/7?
Stuart
HTC Desire S - Vodafone
Android 4.0.4
TT Ver 1.0 (1072278)
Western Europe map version v895.4453
PGPSW Camera Alert
MovieMan
PostPosted: Sun Jul 10, 2005 11:19 pm    Post subject: Reply with quote
It would have been better to taker a supply from the ignition side of the circuit so it was only powered with the ignition on.
Tommy3090
PostPosted: Sun Jul 10, 2005 11:43 pm    Post subject: Reply with quote
But I like the fact that I don't have to wait too long to get a fix.
Satt fix I mean !!
Android 4.0.4
PGPSW Camera Alert
alan_m
PostPosted: Mon Jul 11, 2005 12:39 am    Post subject: Re: Permanent Supply to Wired GPS Reply with quote
Stuart
My TT supplied wired mouse receiver has been connected to the car's 12V power for around 9 months without problems.
xda
PostPosted: Mon Jul 11, 2005 12:49 pm    Post subject: Re: Permanent Supply to Wired GPS Reply with quote
Stuart
No it won't, but you really need to have the supply fused and preferable a switch in the line.
Mine is powered from the radio live feed through a 2 amp fuse and a switch.
The reason for the switch is if at any time you leave your car parked like at Heathrow long term car park foe a week or so you will get back to a flat battery.
The longest I can leave mine powered up is 6 days if I want the car to start, 7 days and I need a jump start.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
julianbarker
PostPosted: Mon Jul 11, 2005 9:57 pm    Post subject: Reply with quote
Mine has been powered 24/7 since January without any problems.
Tommy3090
PostPosted: Mon Jul 11, 2005 10:45 pm    Post subject: Reply with quote
Wouldn't have thought that it would draw that much current, but I think I'll
pull the jack plug from the TT cradle if I'm going to leave it for too long.
Android 4.0.4
PGPSW Camera Alert
CJackel492
PostPosted: Mon Jul 11, 2005 11:14 pm    Post subject: Reply with quote
I leave my TTN cradle and TT BT Mk I receiver permently powered in my car,
Ok, so I never leave my car for more than 1 day without use,
The only thing I've found is that the BT receiver battery has lost performance and only lasts 3-4 hours max,
Suppose I should take it out every few weeks or so to drain the battery,
Carl,
Phones - Nokia 9500 + a few others
Nokia 9500 running TTM5 Sad
View user's profile Send private message AIM Address
julianbarker
PostPosted: Tue Jul 12, 2005 10:00 am    Post subject: Reply with quote
I usually only use the car at weekends and there is no sign of significant battery drain. My understanding is they draw power at less than 100mA meaning a fully charged car battery should allow them to run for a couple of hundred hours before there is a significant impact.
xda
PostPosted: Tue Jul 12, 2005 11:44 am    Post subject: Reply with quote
With power switched off to the Seidio G2100 mount and the TT GPS I can leave the car parked up for 15 days at Heathrow and still start it on my return, leave power turned on and the battery is to low to start after 6 days. Mind you it is a 3.0 ltr V6 automatic. I'll put an Avo into the circuit and see just how much current the unit is drawing.
Graham.
Nokia 925 Windows 8
Neil F
PostPosted: Tue Jul 12, 2005 3:51 pm    Post subject: Reply with quote
My tomtom wired GPS has been powered up since TTN2! I often don't use my car for a week or 2 if the weather is good as I'm on my Vespa (Now fitted with a RAM mount as I kept getting lost without tomtom hehe). I have never come back to a flat battery on the car.
Neil
LiveLifeGoJump
PostPosted: Thu Jul 28, 2005 2:51 pm    Post subject: Reply with quote
I once had an Astra (bows head in shame Embarassed ) which had no false ignition so could not have radio on while in car without engine running (unless I powered radio from permanent feed which I did not want to do as it would be all to easy to forget to switch it off when leaving the car) so I fitted a button switch & relay into the power line. Turning the ignition off with the button pressed, the relay would latch keeping radio supplied with power. Turning the ignition off without the button pressed and the power to radio was switched off.
It's simple to do, may solve your problem!
If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE
22.063 (19 Jun 24)
