Pocket GPS World :: View topic - Poi converter maximum size file?
IAmMrB
PostPosted: Thu Jul 07, 2005 10:36 pm    Post subject: Poi converter maximum size file? Reply with quote
I am trying to convert a axe file to ov2 using poi converter.
The file I am converting has 6300 poi's and is 1.84 meg in size.
When I open this file it tells me it has read 6019 points.
When I load this into tomtom and display, alot of the pois are missing.
I am presuming that it is only able to read 6019 and 281 are missing.
Is this because my original file is too large? or am I doing something wrong?
PostPosted: Thu Jul 07, 2005 11:21 pm    Post subject: Reply with quote
try to save as ASCII and then use MakeOV2.exe - the number of POIs is not limited by TomTom.
IAmMrB
PostPosted: Sat Jul 09, 2005 10:34 am    Post subject: Reply with quote
The reason it wouldn’t convert all of the files is because there is a post code issue with the axe file. Ill makes do with it how it is.
I am having problems getting poi converter to use the icon I have chosen.
I have created a bmp and a pic/PICT file, when I replace the pic file with the new 1, and try to start POI converter it tells me to replace the pic.pic.
Even when I did finally get it to see the new pic file, I would open axe and save as ov2, but I would still end up with poi's default crappy icon.
Has anyone else had this problem?
Oldie
PostPosted: Sat Jul 09, 2005 12:37 pm    Post subject: Reply with quote
The POI limit used to be 10,000 but in POIConverter 3.11 it is now 40,000. Rename your bitmap file to default_symbol.bmp and place it in the folder that contains the program. The folder is C:\Richard_Davies if you used the default installation.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
IAmMrB
PostPosted: Sun Jul 10, 2005 10:16 am    Post subject: Reply with quote
Thanks.
I have done that with the BMP file but I still end up with the original bmp in my new folder with my ov2 file. The instructions say that the bmp and pic files have to be changed.
Oldie
PostPosted: Sun Jul 10, 2005 7:31 pm    Post subject: Reply with quote
IAmMrB wrote:
Thanks.
You are quite correct - it does not work. I used to use my own code to create an OV2 file but now I run the TomTom utility MakeOV2. When making this change I overlooked the fact that MakeOV2 will create a symbol (BMP) file, so my code associated with the use of default_symbol.bmp is now wrong.
I will correct the fault and release a new version when I have the chance.
IAmMrB
PostPosted: Mon Jul 11, 2005 1:53 pm    Post subject: Reply with quote
Ahh,
Well atleast I know now that I wasnt doing anything wrong with the BMP and PIC files, I was trying for ages.
Thanks for your reply.
Will you post in here when you have corrected the fault?
Regards
Jez
22.064 (26 Jun 24)
