Pocket GPS World :: View topic - Postcodes
Postcodes
barleymo
PostPosted: Wed Jul 06, 2005 1:10 pm    Post subject: Postcodes Reply with quote
If it is only giving you 5 digit postcode functionality, I am fairly sure that it cannot see the postcode database.
I found that when I installed TTN5 it put the folder "ZIP" which contains the post code data onto the root of the SD card. A colleague told me it should be on the root of the PDA instead. I moved it there and the 7 digit postcodes worked fine.
barleymo
PostPosted: Wed Jul 06, 2005 1:34 pm    Post subject: Please ignore Reply with quote
Clicked New topic instead of post reply.
Solly
PostPosted: Wed Jul 06, 2005 9:57 pm    Post subject: Reply with quote
Ifyou have put in the ZIP file as suggested, then when you go to naigate select Postcodes instead of city and you will get the full postcode functionality.
Oldie
PostPosted: Thu Jul 07, 2005 12:29 pm    Post subject: Reply with quote
If the ZIP folder is on a storage card then you also need a folder named TomTom on the card. There is no need to put anything in the TomTom folder.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
westentertainer
PostPosted: Fri Jul 08, 2005 4:08 pm    Post subject: Reply with quote
hello my full code searches are not working [i need them for my job] i have created a tomtom folder but when i put in 7 didgit search it still asks me for street etc could you be so kind as to give me step by step instructions many thanks
westentertainer
PostPosted: Fri Jul 08, 2005 4:09 pm    Post subject: Reply with quote
antrichards
PostPosted: Fri Jul 08, 2005 4:38 pm    Post subject: I can't find the ZIP file Reply with quote
I've tried all the listed solutions, but still can't use the full postcode function. I've looked on my card and PDA but can't find the ZIP file - any ideas where it might be?
frank11
PostPosted: Fri Jul 08, 2005 4:54 pm    Post subject: Reply with quote
You have to install the zip file from CD 1
CD1\AddMaps\GreatBritain\GreatBritain Postcodes
westentertainer
PostPosted: Fri Jul 08, 2005 6:52 pm    Post subject: Reply with quote
well i checked inside tomtom folder to see if it was empty like it should be i found there was a voice i use so i created a folder called tom tom . [note the dot] because you cant create 2 folders the same and ay prest it worked many thanks
antrichards
PostPosted: Sun Jul 10, 2005 12:38 pm    Post subject: Thanks very much Reply with quote
Found the ZIP folder on my CD ROM and works like a dream!
antrichards
PostPosted: Sun Jul 10, 2005 1:10 pm    Post subject: I lied..... Reply with quote
I found the ZIP folder and copied it to the My Documents folder on my PDA and ensured the was a folder called 'TomTom' there as well. Started up TTN5 and still the 3 digit postcode search. Moved the ZIP folder to my SD card and made sure there was a 'TomTom' folder there which was empty. Still no joy! Is there any way of just telling TTN5 where to look for the postcode data? I'm at the end of my tether! Crying or Very sad
PostPosted: Sun Jul 10, 2005 1:37 pm    Post subject: Reply with quote
You will need to create a directory at the same level as the map directory. So depending on where your Map Directory is you would see the following -
Map Directory
tomtom
zip
frank11
PostPosted: Sun Jul 10, 2005 3:16 pm    Post subject: Reply with quote
Are you using Navigate to.... Address then imputting Postcode
To get the full Postcodes you have to use
Navigate to....(then on the second page) Postcode
Frank
22.063 (19 Jun 24)
