RichDem Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: 12/12/2002 11:57:47 Posts: 259 Location: East Yorkshire
Posted: Fri Jul 08, 2005 6:08 am Post subject: Map Scrolling Issue with imported POI's |
I have just upgraded to TomTom 5, and on the whole I think it is excellent, As normal with any upgrade I started with no custom POI's in the map folder. When I first used it in anger I was amazed at how smooth the map display was. When I imported my own POI files, speed cams etc the map display speed was back like Navigator 3, all I did was not show my custom POI's and everything was fine,
Is there an answer yet for solving what is more a niggle than a major problem?
I have checked the resolution of all of the custom POI bitmaps and they are all at 16 colours.
On the whole I like it, best version yet.
Regards
Richard _________________ If it ain't broke then fiddle with it until it is! |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Fri Jul 08, 2005 6:47 am Post subject: |
Every time you add a POI category to display or warn it takes up another little portion of the processors time. If there is enough extra workload this can have a noticeable effect on display re-writes.
The answer is to use only those you really need. I have the cameras set as Warn when Near, but all other POI are Disabled under Disable/Enable so that they don't show on map while driving. _________________ Richard
julianbarker Lifetime Member
Posted: Fri Jul 08, 2005 12:57 pm Post subject: |
TT4 could display thousands of POIs in a dozen categories without a problem. TT5 can't - it isn't a processor problem, it is a TT5 problem. Yes, I am sure faster processors wil lcope better wit hthe TT5 bug, but TT4 ran fine. TT5 can't even run fine with one POI category of 30 POIs. I had TT4 running with over 12,000! |
