fatmanscoop Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_005.gif)
Joined: Jul 07, 2005 Posts: 244 Location: Nottingham...
Posted: Thu Jul 07, 2005 6:16 pm Post subject: |
I to seem to be having problems with getting the sound files to work with the speed camera database. The only one that I seam to have is Gatso . all the other sounds are on the TT but how do I get all all the others to work. I went in the the section that shows the POI and then onto the assign sound but do not know how to assign all the other sounds . I am new to this first day with a tomtom go original
App5.2
GPS v1.21
Boot 2.18
Mapv314 |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Thu Jul 07, 2005 6:26 pm Post subject: |
fatmanscoop wrote: | I to seem to be having problems with getting the sound files to work with the speed camera database. The only one that I seam to have is Gatso . all the other sounds are on the TT but how do I get all all the others to work. I went in the the section that shows the POI and then onto the assign sound but do not know how to assign all the other sounds . I am new to this first day with a tomtom go original
App5.2
GPS v1.21
Boot 2.18
Mapv314 |
When you come to the the Select Warning Sound, there are 2 arrows left and right of the screen. If you press one of them it will change the icon in the middle of the page. Tap the Test icon at bottom and you can here the warning.
Tap Select when you have the right warning and continue with the rest.
NOTE: When you use the Warn When Near option more than once for a POI it will ask if you want to Delete. Tap 'NO', unless you want to Delete! _________________ Richard
Posted: Thu Jul 07, 2005 6:38 pm Post subject: sounds |
when i go to POi category i can only see pocketgps uk gatso and camera should i have othe camera poi so i can assign warning sounds |
Posted: Thu Jul 07, 2005 6:45 pm Post subject: |
How many custom POI's have you added? There is a maximum of 27.
Which file(s) did you load from PC to SD card? _________________ Richard
Posted: Thu Jul 07, 2005 6:54 pm Post subject: sound |
on the "mark the POI to display i have 23 ticked i loaded the the ov2 bmp files from the speed camera database download |
Posted: Thu Jul 07, 2005 6:56 pm Post subject: Re: sound |
fatmanscoop wrote: | on the "mark the POI to display i have 23 ticked i loaded the the ov2 bmp files from the speed camera database download |
If you have 23 ticked, how many have you got unticked? _________________ Richard
Posted: Thu Jul 07, 2005 9:13 pm Post subject: |
sorted thanks |
Posted: Thu Jul 07, 2005 9:15 pm Post subject: |
Good news. :D :D _________________ Richard
Posted: Thu Jul 07, 2005 10:13 pm Post subject: |
just had a little run round and still not working correct all i get is GATSO and not the correct speed for the camera what am i doing wrong i am normaly ok with techy things...i see pocketworld..gatso spec etc in POI but not individual speeds.. as i said just passed a 30mph gatso and it just said Gatso |
rayflan Frequent Visitor
![](modules/Forums/images/avatars/265178757431f9c5ddb971.gif)
Posted: Thu Jul 07, 2005 10:23 pm Post subject: |
fatmanscoop wrote: | just had a little run round and still not working correct all i get is GATSO and not the correct speed for the camera what am i doing wrong i am normaly ok with techy things...i see pocketworld..gatso spec etc in POI but not individual speeds.. as i said just passed a 30mph gatso and it just said Gatso |
Did you see what icon ttgo displayed ?. It maybe a camera in the tba file _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
Posted: Thu Jul 07, 2005 10:28 pm Post subject: |
yes it displayed the correct logo Gatso but didnt say Gatso 30mph just gatso.. |
Posted: Thu Jul 07, 2005 10:36 pm Post subject: |
The logo should of being a 30mph speed limit sign. have you used the speed zoned ov2 files ie pockectgps_uk_gatso_30.ov2 _________________ Ray
Visit my site |
Posted: Thu Jul 07, 2005 10:41 pm Post subject: |
how do i correct this..when i check my POI to display it only shows the main title to each camera ie Gatso..Specs no individual camera speed signs.. |
Posted: Thu Jul 07, 2005 10:46 pm Post subject: |
In the zip file you downloaded from pocket gps a folder called speed zoned contains the files you need. _________________ Ray
Visit my site |
Posted: Thu Jul 07, 2005 11:19 pm Post subject: |
is this the only file i need i copied the contents and pasted them to my sd card went for a run around block and it still only says GATSO no 30 mph icon just gatso.i allso installed the contents ov2 bmp to sd card as well as speed zone from said zip file.is this correct |
