Pocket GPS World :: View topic - Route from current location
Mamba
PostPosted: Tue Jul 05, 2005 11:47 pm    Post subject: Route from current location Reply with quote
I'm a new user of PMN. Is there an easy way to build a route from your current location (or Home) without having the GPS on? I'd like it to route to, say, an Outlook Contact address (which I know it can do) from a manual entry or remembered location, then be able to save or "Go" that route. The regular "create route" interface is kinda awkward in comparison.
Kar98
PostPosted: Wed Jul 06, 2005 2:48 am    Post subject: Reply with quote
OK, I just checked, and discovered about a dozen different ways to accomplish what you seek. So as to keep my efforts to a bare minimum, which method are you using now?
Mamba
PostPosted: Wed Jul 06, 2005 5:32 pm    Post subject: Reply with quote
I've been trying to use the "Destination" icon, then choosing "Contacts". But it seems without the GPS connected it always tries to use the last known location as the Origin current location.
I'm just looking for the best shortcut method to get the Origin and Destination into a route I can save or "Go", using pre-defined addresses (like in Contacts).
Mamba
PostPosted: Wed Jul 06, 2005 5:33 pm    Post subject: Reply with quote
cgavula
PostPosted: Fri Jul 08, 2005 4:09 pm    Post subject: Reply with quote
If I'm understanding your problem then I suggest you do the following:
Go into Map mode. scroll the map until you find the place you want to be the origin (or use FIND - Address, FIND - CONTACT, etc.) or just find the location you are currently at and click and hold that point on the screen to select it. Once you have a location selected, click the mailbox icon and choose "set as origin". Then do the same, finding your destination location and choosing "set as destination".
Then it's simply a matter of choose ROUTE - CREATE from the menus at the bottom of the screen. You can then save the route if you'd like. Make sure, of course, that you have the local maps for both your origin and destination locaded as well as all the major road maps (the highway grid maps) needed to connect the two points or this won't work.
--Chris
Mamba
PostPosted: Mon Jul 18, 2005 10:59 pm    Post subject: Reply with quote
Thanks..that helps some. But I somehow have a point in there (a pinned star) that I just can't get rid of that keeps wanting to be the Origin...where the $#@! is the "Delete"? I've tried "Clear" under Route but it doesn't go away. If I hold the "+" by the address for that entry all I get are things like "Set as Destination, Set as Origin", etc...I just want it to go AWAY!
cgavula
PostPosted: Fri Jul 22, 2005 8:19 pm    Post subject: Reply with quote
I have that too - the star with the pushpin in it, but it doesn't stop me from selecting other road segments (they will go pink/lavender when you select them) and then clicking on the mailbox icon and choosing "Set origin...". Is your setup not responding this way? As a dumb question, are you running version 3.12 or an earlier version? I know you said you are a new user, but that doesn't necessarily mean you are running the current version.
--Chris
Mamba
PostPosted: Sat Jul 23, 2005 12:41 am    Post subject: Reply with quote
Yes...3.12. Somehow I got it to work. Main difficulty is that the "Current Route Point" dropdown is VERY finicky...have to select the down arrow a few times before I get a list to choose from. I was then able to set my O: and D: properly...thanks.
23.054 (28 May 25)
