Pocket GPS World :: View topic - ttg fixed supply
ttg fixed supply
ned1
PostPosted: Mon Jul 04, 2005 9:37 pm    Post subject: ttg fixed supply Reply with quote
Hi, I would like to fix a supply in my car without using the lighter (to big with wires in the way), with a in line fuse, switch and transformer, can you get some sort of car adaptor and if so where from.
ned
PostPosted: Tue Jul 05, 2005 1:02 am    Post subject: Reply with quote
As you've mentioned a transformer, you've not fallen into the first trap that several people on the forums have - assuming you can just wire a power plug into the car's wiring. 12 volts up the TomTom's 5 volt input = "bang"
However, what you DON'T want is a transformer! Transformers only work with A.C. current.
You WOULD use one in, for example, the TomTom mains adaptor, where it is used to reduce 120/240 mains voltage down to a few volts A.C. and then additional components (rectifier diodes, capacitors and possibly a regulator I.C.) are used to convert the A.C. into 5V D.C.
But in the car you have D.C. already, so it only needs to be put through a regulator circuit to reduce it down to 5V.
As this circuitry is what is already present in the cigar lighter plug, the easiest way (IMHO) is to buy an extension lighter socket cable, cut off and discard the plug end and wire the lead into the car electrics. Then just plug the TomTom adapter into the new socket and lose the whole lot behind the dashboard.
That's how I'll be doing it when I stop being so bone idle!
PostPosted: Tue Jul 05, 2005 1:11 am    Post subject: Reply with quote
Forgot to mention - you can get extension leads from Maplins for £2.99 or just a cable mounting socket for 99p. Halfors probably do something similar, too.
ned1
PostPosted: Tue Jul 05, 2005 9:21 am    Post subject: Reply with quote
Thanks for that Andy,
Sorry to a pain but have you a part # for it to make sure I get the right bits.
Ned Wink
ned1
PostPosted: Tue Jul 05, 2005 9:30 am    Post subject: Reply with quote
When you say "cut off and discard the plug end" are you talking about the
part on the ttg that plugs into the lighter or the other way round !!
please give me a idot's guide Embarassed
rkm_hm
PostPosted: Tue Jul 05, 2005 1:05 pm    Post subject: Reply with quote
He's talking about buying a cigar lighter extension lead. This is a cable with a plug on one end and a socket on the other end. Cut the plug off this extension lead - don't touch anything supplied by TomTom. Plug the plug of your TomTom car adaptor into the socket of the extension lead. Connect the other end of the extension lead - which is now bare wires where you removed the plug - into some suitable point in your car's electrical system.
Tape the plug and socket together, and hide them somewhere behind the dashboard.
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
ned1
PostPosted: Tue Jul 05, 2005 2:44 pm    Post subject: Reply with quote
Ok great, got it, thanks Roger and Andy
Rolling Eyes
22.064 (26 Jun 24)
