markyhedgehog73 Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_020.jpg)
Joined: Jun 03, 2005 Posts: 95 Location: East Yorkshire
Posted: Mon Jun 27, 2005 9:14 pm Post subject: POI warnings |
Hi everyone
is it possible to add different poi warnings into tomtom 5?
and if so how?
also does anybody have the software for full postcode in tomtom 3 for pocket pc? cos i cant seem to find it to download anywhere.
Thanks :D :D |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Tue Jun 28, 2005 6:55 am Post subject: |
Have a read of this thread. It might be of some help. _________________ Richard
Posted: Tue Jun 28, 2005 8:27 pm Post subject: |
thanks for the reply,
any advice on the second part of question from anybody??
many thanks.
(cheers oldboy) |
soweezy Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Posted: Wed Jun 29, 2005 10:43 am Post subject: Re: POI warnings |
markyhedgehog73 wrote: |
afraid I deleted my copy when I installed TT5 (not a good idea)
I've read on these forums you can use the Great_Britain.Postal file from TT5 to add full postcode lookup in TT3... you'll have to search for it though
btw, it's probably illegal to do so ![Confused](modules/Forums/images/smiles/icon_confused.gif) _________________ SW
Garmin Zumo 390LM |
Posted: Wed Jun 29, 2005 2:47 pm Post subject: |
Thanks for the response will try pc's from version5 if that dont work the missus will have to do without for now til i can afford v5 for her!! |
BBill Occasional Visitor
Posted: Thu Jun 30, 2005 3:01 pm Post subject: |
Marky
I think you're looking for the digitools.co.uk site for TT3 postcodes,
but it had to go due to copyright issues.
"copied from another thread...
Step One
First of all you need to download and unzip the release into a temporary location. The full package is a large download (11.5MB) which includes the initial release of the database, so be patient if your link is slow.
The zip file contains five files: ukpostcode.dat which is the database, ukpostcode.exe which is the application used for the look-up, setup.exe which installs the TomTom hook, TTNControl.ini which controls the install, and TTNControl.arm.CAB which is the actual interface to TTN.
Step Two
Place your PocketPC in the cradle and connect to the PC using ActiveSync.
Step Three
Note that if you've already got CheckPOInt installed you don't need to complete this step. CheckPOInt will already have installed the necessary TTN support files. Simply carry on from step four.
Use Windows Explorer to copy the 'TTNControl.arm.cab' file to the 'My Documents' folder on your PPC. Then, using File Explorer on the PPC, locate this .cab file and double tap to install it. The .cab file will self delete following installation.
Step Four
Use Windows Explorer to browse your PocketPC. Locate your storage card, create a folder called 'ukpostcode' on the storage card and copy ukpostcode.exe and ukpostcode.dat to it. It is important that the .exe file is in the same folder on the PocketPC as the .dat file, or it won't work.
Finally, create a shortcut to ukpostcode.exe and drag it to the "Windows\Start Menu\Programs" folder on the PocketPC (don't drop it in \windows\programs - it won't appear anywhere). This allows you to use the usual PocketPC method to attach ukpostcode to one of your hardware keys, or make it appear in your main menu. Having it hooked to one of the hardware keys is a particularly convenient way of accessing the program when TomTom is running.
Using the program
Simply start the ukpostcode program using the shortcut you created in step four above, from your start menu. Type in a postcode and click on either "Show on map" or "Navigate to", as appropriate. If all is well, TTN should automatically pop up in either map mode or navigator mode. |
keith9534 Occasional Visitor
Posted: Sat Jul 02, 2005 11:41 am Post subject: |
Can anyone help if after following the instructions it won`t work?
I`m using TTN3 with an IPAQ 3630.
I have checkpoint installed but whenever I try to run the program it just says "cannot find ukpostcode or one of its components"
Anyone? |
Posted: Sat Jul 02, 2005 11:54 am Post subject: |
Sorry....just looked through some old posts and it looks like the version of software you are running on your PPC makes a differnce
Now need to find out what version mine is running. |
Andy_ Occasional Visitor
![](modules/Forums/images/avatars/165821651642c8115c26baf.gif)
Joined: May 28, 2005 Posts: 29 Location: Kent, England
Posted: Sat Jul 02, 2005 12:18 pm Post subject: |
Just read those instructions to install full uk postcode search....
Is this using the files from TTN5 or from downloading from the site that is no longer running?
Are these files available anywhere???
I'm sure no-one will use them if it's illegal,,,,, but it would be nice to just look!!!
:D |
Posted: Sat Jul 02, 2005 12:37 pm Post subject: |
Andy_ wrote: | Just read those instructions to install full uk postcode search....
:D |
those were the instructions for ukpostcode program not TTN5 postcodes
you'l have to search for the TTN5 postcodes instructions, although I think you only need create 2 folders called TomTom and Zip on the SD card and copy the Great_Britain.Postal file into the Zip folder
I'm pretty sure this is illegal, even if you own TTN5 and TTN3... no doubt someone will know _________________ SW
Garmin Zumo 390LM |
Posted: Sat Jul 02, 2005 12:39 pm Post subject: |
Andy check your pm |
Posted: Sat Jul 02, 2005 12:41 pm Post subject: |
I only have TTN3,, didn't fancy 5 considering all the reviews!
Full postcode use would be handy! |
