max2thous2 Occasional Visitor
Posted: Sat Jul 02, 2005 12:37 am Post subject: Just downloaded the Pocket GPS GATSO files Help! |
I have just dowloaded the POI Gatso files from Pocket GPS thanks guys much obliged. However the instructions for installing the POI are a little vague .
I am trying to install them onto my Nokia 6600 . However the text filr Which files do I need states :
> ov2 and bmp files
TomTom Go, Navigator 1/2/3, Palm, Mobile and HP Navigation Kit
There are many folders containing many files of ov2 and bmp files. Which ones are the ones i need.
Additionally do i need to keep them in the directory that they are located when they are copied to my country directory on my mmc?
I understand the directories with the alternaltive bmp.
Do i need the wav files the speed zoned, the single file version and the ov2 bmp files.
Am a little confused vcan anyone help or shed a light? |
Oldboy Pocket GPS Moderator
Posted: Sat Jul 02, 2005 8:15 am Post subject: |
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' files.
Third is the full 13 file version that divides the Gatso and Mobile files into speed zones. There are 7 each of the Gatso and Mobile files. These are found in the 'speed zoned/gatso/ov2 bmp' and speed zoned/mobile/ov2 bmp' folders. Add to these the Specs, Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder.
When you've decided which set you want copy each .ov2 file, and it's matching .bmp file to your map folder. Then setup the POI's in Manage POI. _________________ Richard
