Pocket GPS World :: View topic - EventwakeupTomTom error help.
Goto page Previous  1, 2
PostPosted: Thu Jun 30, 2005 7:13 pm    Post subject: Reply with quote
http://www.pocketgpsworld.com/downloads/check_notifications.exe
mhpreston
PostPosted: Thu Jun 30, 2005 7:41 pm    Post subject: Reply with quote
Ta! Smile
jaybee001
PostPosted: Thu Jun 30, 2005 9:36 pm    Post subject: Reply with quote
I had this too (not that TT5 is actually working, but that's another thing) - it got solved afer a soft reset
stu14t
PostPosted: Fri Jul 01, 2005 4:55 pm    Post subject: Reply with quote
mhpreston wrote:
Sorry to ask a silly Q - where can I find check_notifications.exe on my PDA? - Pocket PC
Matt
Matt,
Please look back to early posts in this thred from lbendlin of where to downlad Check_Notifications as it is a third party program from a company called ScareyBear software. it is free to download just put check notifiactions in a google search
Tomtom GO 710 + TMC RDS
Ipaq 2210 6GB CF II Microdrive
TTN5 with Holux CR-100/ Globalsat 338 BT
kipper9999
PostPosted: Sun Jul 17, 2005 8:41 am    Post subject: Reply with quote
I have upgraded to tom tom 5 too. Also having the wake up notification alert.
I have tried the check notification fix, but it still occurs each time i switch off and switch on while running TT5 ,(compaq 3850)
Has anyone got any other possible fixes please ?
Is it possible to upgrade the operating software for a fix ?
It is very annoying !!!!!
Ant
stu14t
PostPosted: Sun Jul 17, 2005 11:43 am    Post subject: Reply with quote
Hi Ant,
It depends on your original PDA vendor.
This is a problem associated with Windows Mobile 2003 where notifications of events such as program starts and soft resets are not cleared from a database when they should be.
In an ideal world we would be able to upgrade to Windows Mobile 2003 Second edition, which has cured this. Not all PDA’s are sent out with SE and most companies will not provide an upgrade.
Notification events will only cause problems if they start to multiply
I have found other software which will automatically clear duplicate event notifications after a soft reset (This is what causes the problems) and you can also manually delete any other troublesome entries. The program is called MemMaid form Dinar software and is available from:
Handango or Pocketgear
And there is a useful page on how to use Here
DO NOT DELETE EVENTS THAT YOU DON’T KNOW. IT MAY CAUSE SERIOUS POBLEMS
kryten
PostPosted: Mon Jul 18, 2005 10:27 am    Post subject: Reply with quote
If this is an OS fault, why does this happen with TTN5 and never happened with TTN2/3? I don't recall seeing this with any other application on the PPC (and I develop GPS tracking software for them!)
The whole point of PPC architecture is you can turn it off and have things ready to go when turned back on. Having to soft reset is a complete pain.
I also noticed that my 'charging' light (on ipaq 3870) wouldn't come on after having this error - as soon as I reset it was back.
COLINRG
PostPosted: Tue Jul 19, 2005 12:24 am    Post subject: Reply with quote
Just installed the update to version 5.10 and it seems to have fixed the error.
Anyone else found this?
TPFKAS
PostPosted: Fri Dec 09, 2005 3:38 pm    Post subject: Reply with quote
I know this is an old thread, but I have to bring it up again.
I am also having this notification error and I tried all of the solutions suggested in this thread to solve the problem.
Let me give clear description of the situation.
I am running TT5 on an IPAQ3850 running PocketPC 2002.
After a clean install I do get the notification error when I power up the unit after a shutdown while TT5 was still running.
When I don't have TT5 running neither check_notification nor MemMaid have entries I would have to delete according to the posts in this thread.
When I have TT5 running and start up the check-notification program I can see the EventWakeUpTomTom running and I can delete it. If I delete it, I can power off and on again without shutting down TT5 and there is no notification error. Smile
However, when I completely stop TT and start it up again, the problem is back. When I then shut down the IPAQ and power on again, the notification is there again. Sad
Same for MemMaid. When I have TT running I can see an entry called "\\.\Notifications\NamedEvents\EventWake..etc". There are no duplicates. When I delete the entry the notification does not pop up anymore after switcing off and on. Smile
However, when I stop TT and start it up again, the problem appears again after powering off and on. Sad
All in all, both MemMaid and check-notification can solve the problem, but only until I restart TT.
I upgraded to 5.1 and 5.21, but there is no change in behavior.
I also upgraded to PocketPC 2003 and this does solve the problem, but in return I get another one: the charging process over the sigarettelighterplug in my car will stop after some time running TomTom.
Did anyone find a permanent solution to this problem?
TPFKAS
PostPosted: Mon Dec 12, 2005 9:12 pm    Post subject: Reply with quote
Mmm, apparently no definite solution under Windows PPC2002. I have upgraded my 3850 to PPC2003. Upgrades float around at eBay for less than $2.
PostPosted: Mon Dec 12, 2005 9:31 pm    Post subject: Reply with quote
The solution is to exit TTN before you send your PDA to standby ("switch it off").
the OS upgrade you purchased on eBay is illegal - please do not discuss this here.
TPFKAS
PostPosted: Mon Dec 12, 2005 9:52 pm    Post subject: Reply with quote
Sorry..I didn't know. But out of curiosity: HP doesn't sell it anymore. Is there a legal option to upgrade?
Page 2 of 2
22.093 (18 Sep 24)
