Pocket GPS World :: View topic - Poi and Medion 95900
ferjan
PostPosted: Thu Jun 16, 2005 4:50 pm    Post subject: Poi and Medion 95900 Reply with quote
I have got Poi speed camera software installed on my MD95900...one question..how do you access it please, if you tell me via Activesync then I have got another problemas I can not get Activesync to work on my computer.. everytime I try and run it I get the message there is a problem with Activesync you need to rerstart you computer to resolve this problem...so I do that and it's still the same old message any help on these would be appreciated.
P.S I am running XP pro and SP 2 if that helps.
chippy436
PostPosted: Thu Jun 16, 2005 6:43 pm    Post subject: Reply with quote
i am stuck with the poi, but i had the same issue with activesync, i had to remove it from my pc and then restart the pc and then re-install activesync.. this worked on the 2nd attempt.. was very frustrating..
but try removing it then restart and re-install.
ferjan
PostPosted: Fri Jun 17, 2005 10:05 am    Post subject: Thanks Reply with quote
Thanks Chippy436 I will give that a try...lets hope it works hi.
Waffty
PostPosted: Mon Jun 20, 2005 6:07 pm    Post subject: Re: Poi and Medion 95900 Reply with quote
I've had a similar problem i.e Activesync doesn't appear to work out of box in partnership mode but it will allow me transfer files via the guest mode option.
I'm interested in performing a full backup (in guest mode) but everytime I kick it off, it complains that the "disk is full". I've changed the preference location for the Backup.stg file but I still get the same error.
So I guess my question is, can I backup my system in guest mode and why can't I setup a partnership ?
Also, even using guest mode, I managed to get the POI working. I simply found a copy of taskbar hack. Copied it into the start up folder, rebooted and followed the instructions from this site.
Many thanks in advance.
GPS_RoadHog
PostPosted: Mon Jun 20, 2005 6:23 pm    Post subject: Reply with quote
I have discovered there is no need to hack the os / install task bar to install speed camera software.
TomTom Via 135
qwackers
PostPosted: Thu Jun 30, 2005 11:52 am    Post subject: Reply with quote
read somewhere that partnership won't work as it is a PNA not a PDA (the 95900 that is) though you can still copy/delete files ok in guest mode.
As for the backup, I'm also looking for an answer to that one.
Hooloovoo
PostPosted: Thu Jun 30, 2005 12:06 pm    Post subject: Reply with quote
The only thing you need to back up are the favoruites.txt file which contains all your saved locations, and the contents of your routes directory which contains any multiple-destination routes that you've saved.
Everything else is on the CD that came with it. Plus, if you haven't edited anything on the memory card you don't even need the CD. Just switch it off on the back and then on again and everything will reinstall fresh.
Basically all you need is the favourites.txt file.
Waffty
PostPosted: Fri Jul 01, 2005 3:03 pm    Post subject: Re: Poi and Medion 95900 Reply with quote
Thanks for that Hooloovoo, it's good info to know.
Waffty.
GPS_RoadHog
PostPosted: Fri Jul 01, 2005 3:56 pm    Post subject: Reply with quote
You will find though that the favourites.txt file remains in memory, even after a hard reset!
TomTom Via 135
