![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Mon Jun 27, 2005 5:05 pm Post subject: XDAIIs keyboard disable - how? |
OK, had all the fun getting tt3 to work on the xda to no avail - now loaded tt5 and the unit works but i need to use a bt headset so have purchased a wired gps - to use it i need to disable the keyboard and possibly the ir port (hope not as i need it) - how do you do this any help much appreciated - thanks mike |
Crocodile Regular Visitor
Posted: Mon Jun 27, 2005 6:01 pm Post subject: |
All you need to do is uncheck "accept all incoming beams". Don't have an XDA2s anymore but I think it was in "connections". If you still stuggle just search on the phrase, it's been documented on this site & others many times.
This is possibly all that was wrong with TTN3 as I had TTN3 working on a XDA2s with a wired receiver without any problems.
Looking to sell your 4700? |
Maxi Regular Visitor
Posted: Tue Jun 28, 2005 8:19 am Post subject: |
Start > Settings > Connections (tab) > Beam |
StevenGourlay Frequent Visitor
![](modules/Forums/images/avatars/185987854445be6a220df05.jpg)
Posted: Tue Jun 28, 2005 12:03 pm Post subject: |
you will have to use the hardware keyboard for now untill tomtom bring out a fix to use the software keyboard. _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
Posted: Tue Jun 28, 2005 7:11 pm Post subject: |
thanks for letting me know - tt5 yet another bug - i am going to go back to tt3 and sort out the gps problem as tt5 offers little i actually need and i don't like the user interface may take some time for the xda to do what i want, at least tt3 uses the screen keyboard the xda is great but you cannot use a bluetooth headset and bluetooth gps at the same time, when you terminate the call the gps disconnects as well, thought wired gps would sort it all out but not to be - cheers - mike |
Posted: Wed Jun 29, 2005 9:32 am Post subject: |
There is another known problem with tomtom 5 and palm t5 when you run tomtom it asks to activate the program ever single time. _________________ Regards
Steven Gourlay
Posted: Fri Jul 01, 2005 8:47 am Post subject: |
Ok another hard reset (the XDA has had more in four weeks than the ipaq has had in twelve months), this time I opted for a "corporate" install to avoid the O2 rubish on the user interface, it will make the machine more stable - jury is out on that one at the moment.
As I stated before not happy with TT5 so I re-loaded up TT3, and then loaded TT GPS driver 2,06 as sugested within these forums - its still the same GPS works, sat nav works but the Bluetooth headset will "Pair" but fails to connect, so you can't use it. It must be the GPS driver that is causing this fault as TT5 works fine with the headset - I just don't like it and it is problematic using the inbuilt keyboard as the on screen unit will not come up in all modes of operation - any thoughts would be appreciated, secondly has anyone out there got an O2XDAIIs, running TomTom and using a bluetooth headset, I would like to know that it does work and I am begining to suspect the unit is in fact faulty - Mike |
Posted: Fri Jul 01, 2005 12:32 pm Post subject: |
Mike
Which ROM are you running because I was under the impression you could run BT TomTom and a BT headset at the same time without any problems. The latest ROM - v1.31.139 - should have fixed any Bluetooth problems on the XDAIIs.
http://www.my-xda.com/xda2s_soft.html |
Posted: Fri Jul 01, 2005 12:41 pm Post subject: |
Maxi, the details are below, this is the latest stuf from the O2 web site
ROM 1.31.00WWE
ROM DATE 12/13/04
RADIO VS 1.06.00
Protocol 1337.38
Ext ROM 1.31.139.WWE
If I down load from the link you supplied will my O2 stuff still work including the GPRS
Cheers - Mike |
Posted: Fri Jul 01, 2005 12:52 pm Post subject: |
Mike
It looks like you've already got the new ROM on your unit. I've not actually got it on mine because its an older unit. I dont use a BT headset and my TomTom works fine so I've never bothered downloading the new one. I'm afraid my techie knowledge is very limited so cant help you much more. If you dont get any luck here try the Tekguru forums, theres bound to be someone there that can help.
http://www.tekguru.co.uk/phpBB2/viewforum.php?f=24 |
Posted: Fri Jul 01, 2005 12:55 pm Post subject: |
I downloaded and installed that (40MB) about two weeks ago, but thanks for the info anyway, if you ever do get a BT headset make sure you take the XDA withyou and get the shop to prove it will work with your unit - Mike |
