Pocket GPS World :: View topic - use specific motorway
slast
PostPosted: Tue Jun 28, 2005 1:07 pm    Post subject: use specific motorway Reply with quote
Apologies if this is somewhere in FAQ but I can't find anything on search...
There must be a technique to tell it to use a specific motorway or named road but I'm blowed if I can find it! E.g. I have tried setting rest areas from the POI as way points but it then goes into the rest area itself, and there are some sections with no suitable rest area...
Steve L
Jim-Bob
PostPosted: Tue Jun 28, 2005 1:25 pm    Post subject: Reply with quote
Let it plan the route the way it wants then go to navigate via point on map then select the motorway you wana go down.
bmwman
PostPosted: Tue Jun 28, 2005 4:19 pm    Post subject: Reply with quote
Absolutely - but you'll need to focus/zoom in tightly to the motorway/junction in question to select your Point on the Map. Setting Waypoints when zoomed out is just as likely to pick up the wrong side of the road, or the exit slip coming the other way so it routes you many miles around the countryside to ensure you go smack bang through the Waypoint.
Rich
benlast
PostPosted: Tue Jun 28, 2005 4:27 pm    Post subject: Reply with quote
Hmmm... don't come across many other people with the surname "Last", so I definitely need to help if I can!
Do a normal "navigate to". Then go to "browse map" and locate the road/motorway you want to travel via. Be sure to select the road itself, not a location close to it. You'll know you've done that when the road/motorway turns green to show it's selected. Click the "cloverleaf" icon and choose "travel via". Now your route will travel via that road.
ben
PostPosted: Tue Jun 28, 2005 6:28 pm    Post subject: Reply with quote
If you goto http://www.dirksoft.co.uk/tom_tom_go.htm you will find a POI compendium. In there is a Motorway junction POI which covers Motorways and Ax(M) roads.
Originally created for Breakdown Recovery it lists the points to join any Motorway at a particular junction and travel N,E,W or S, ie. M1 19N or M4 17W.
I've had no complaints, yet, so it must be OK. Rolling Eyes
slast
PostPosted: Wed Jun 29, 2005 10:12 am    Post subject: Reply with quote
Thanks for all that, folks....
I am finding it a bit frustrating that it seems to recalculate from scratch every time one adds a new "via", and throws away all previous waypoints, but I guess I will figure something out. The references to the existing POI lists are very helpful, thanks again
Steve
steveJ
PostPosted: Wed Jun 29, 2005 4:06 pm    Post subject: Reply with quote
If you use 'navigate to' you are limited to one waypoint (travel via). If you want multiple waypoints just use 'itinerary' planner instead.
steve J
22.062 (12 Jun 24)
