GerryC Pocket GPS Moderator
Posted: Thu Jun 23, 2005 9:46 pm Post subject: Where did TomTom get the postcodes from for TTN5? |
When I upgraded, I thought I'd check some "known" postcodes to see how it works. It's disappointing to see that not only is my current postcode going to the wrong street, so is my parents and where I'm moving to.
Each time, it has a different road on the same estate. I can only guess that they plotted a single point for each postcode and then took the nearest street name to that point. If so, this would seem to be a bit dodgy.
If they had checked against ANY official postcode system, they would have had the right road name and maybe would have been able to plot the dot in the right place (ie on the road it refers to).
Is this a general problem across the country or am I just extremely unlucky? :x _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
julianbarker Lifetime Member
Posted: Thu Jun 23, 2005 9:52 pm Post subject: |
I have been using the postcodes ot navigate ot farms - TT gets me straight to the farm gate in most cases, just sing the postcode. |
nnishp Occasional Visitor
Posted: Fri Jun 24, 2005 1:15 am Post subject: |
i have this problem too, my road doenst come up as my postcode on ttn5, it takes me elsewhere |
Oldboy Pocket GPS Moderator
Posted: Fri Jun 24, 2005 6:40 am Post subject: |
Each Postcode generates a lat/long which TT then links to the nearest road. Then a house number, or crossing, is requested for added accuracy.
If roads are close together it is possible for TT to latch to the wrong road. _________________ Richard
jupiter Occasional Visitor
Posted: Fri Jun 24, 2005 11:58 am Post subject: |
Hmm. The postcode app that digitools used to do was excellent until he had to take it off due to copyrights! :x |
sland Regular Visitor
Nomada Regular Visitor
Posted: Fri Jun 24, 2005 12:45 pm Post subject: |
Hi All
Oldboy wrote: | Each Postcode generates a lat/long which TT then links to the nearest road. Then a house number, or crossing, is requested for added accuracy.
If roads are close together it is possible for TT to latch to the wrong road. |
That's the way Niels add-on or mine works, but not sure at all is the system TomTom adopted.
I stand to be corrected, but Postcodes in TomTom only will work if you have the map for them.
TomTom Postcodes came from TeleAtlas maps and they are linked to objects in the map. Again standing to be corrected.
I did proposed time ago a test: May be somebody knows a new settlement, made in the last two years, that still not in maps, but with well known postcode.
Just type the postcode and let us know if you get it. Even in midle of nowhere, like woudl be the case with digitools add-on or mine.
That could enlight if postcodes and objects in maps are or not dependants and if they are then to be in a place or other is just an error in the database. _________________ Jose Adell
www.geopostcode.com |
blurredout Occasional Visitor
Posted: Fri Jun 24, 2005 12:54 pm Post subject: |
I am interested in knowing what maps people are using when they get these problems, are they the GB map or the GB PLUS map?
Also could someone give some example postcodes that show this problem. |
Posted: Fri Jun 24, 2005 2:23 pm Post subject: |
You have to be careful with postcodes - in the past I have used navigation systems based on full post codes which have failed - for example, becasue the property is new and the post code in the database shows the post code as being at the local sorting office, not at the new street (even where the street is included) - or, in the case of a buisness that had its own postcode - the business moved and took the post code with it, but the database had not been updated. Similarly, I have found that navigating to Government Offices by postcode can be pointless as the postcode may refer to the location post is delivered and sorted, not to the location of the building in the address. |
Posted: Fri Jun 24, 2005 6:24 pm Post subject: |
Nomada wrote: |
I stand to be corrected, but Postcodes in TomTom only will work if you have the map for them. |
The TomTom Postcode file will apparently work with the older maps, so I assumed that they return a lat/long similar to a normal Navigate to Address. _________________ Richard
Posted: Sat Jun 25, 2005 12:52 am Post subject: |
Hi Oldboy,
Oldboy wrote: | The TomTom Postcode file will apparently work with the older maps, so I assumed that they return a lat/long similar to a normal Navigate to Address. |
It could be, I don't know. I just know what I was told by OS about the way postcodes are bundled in TeleAtlas maps, as they proceed too from OS.
Regards, _________________ Jose Adell
TomTom-Paul Occasional Visitor
Posted: Sat Jun 25, 2005 1:20 am Post subject: |
blurredout, try B6 4AA in either of the uk maps.
It should point to St Stephens Street which is due north of where it does point.
Geopostcode got it right.
Paul |
Posted: Sat Jun 25, 2005 1:32 am Post subject: |
Hi Paul
TomTom-Paul wrote: | blurredout, try B6 4AA in either of the uk maps.
Paul |
Well, I want to be honest here. I did check it and my add-on and ttn5, withouth any house number, then both are in the same point. What happens is that TTN5 gives it for High Street as it is the nearest street. But look at the cursor in the centre of the screen, it is the real position for the postcode, whilst High Street is on the left of the screen. _________________ Jose Adell
Posted: Sat Jun 25, 2005 1:42 am Post subject: |
I thought you had to enter a house number when it asked.
Paul |
Posted: Sat Jun 25, 2005 1:46 am Post subject: |
Hi Paul,
Paul |
I think to have read in this forum house number are just shared proportionally in the leg of street in TomTom program, but not for real.
When I was working as courier I tried several times to include the house number, only to get away from the place. Postcode was much more accurate. _________________ Jose Adell
