Pocket GPS World :: View topic - Please help with traffic
matty_doodle
PostPosted: Thu Jun 23, 2005 6:03 pm    Post subject: Please help with traffic Reply with quote
Hi there,
Just got my TTGO 700 today :D and am loving it. I do have a query, I'm trying to try out the 1 month trial with the traffic. I have paired my phone with the TT and it is all conected via bluetooth fine. But once I have input my email address and the word plus for the user name it comes up with "could not connect to service" Sad I have checked with O2 (who I have a normal pay monthly service and they say everything is fine from their end and the phone does have gprs enabled.)
Can anyone out there PLEASE HELP!!!!
Many thanks
Matt Smile
Wakey
PostPosted: Thu Jun 23, 2005 6:38 pm    Post subject: Reply with quote
Firstly go to the email account that you entered.
there'll be an email telling you the account is active and the new password you'll need to use when reconnecting to any of the services.
hope this helps.
matty_doodle
PostPosted: Thu Jun 23, 2005 8:23 pm    Post subject: Reply with quote
Hi Wakey,
I tried this and it didn't make any difference, has anyone got the traffic to work? If so how!!!
Many thanks
Matt
radavis
PostPosted: Thu Jun 23, 2005 8:32 pm    Post subject: Reply with quote
Silly question, but after pairing the Go and the phone have you set up a new connnection?
If not, this may be of help.
Mobile Web Bluetooth Settings
Pairing the devices
Tap on the Bluetooth manager icon and make sure the Bluetooth radio is turned on Now Tap on the Bluetooth manager icon again then tap on the Bluetooth manager option make sure that Bluetooth is turned on on the handset On the iPAQ tap on Tools->paired devices Click on Add then click on the search Icon which looks like a magnifying glass on paper located to the right of the Device field Tap on Your handset name and enter any passkey then press OK Press Accept or Yes on the handset and then enter the passkey which you entered into the iPAQ on the handset You should now see your handset ID displaye on the iPAQ screen, press OK
Tap on New->Connect select Connect to the internet option and press Next
Select Connect via a dial-up device such as a cellular phone then press Next Tap on where it says "Tap here to choose a device" and select your handset name Leave create a shortcut for this connection Ticked and then click Finished Tap on New Connection... and enter the following: - Connection Name: O2 Mobile Web Bluetooth Country Code: Leave blank Area Code: Leave blank Phone Number: *99# for Nokia handsets OR *99***CID NUMBER# for Sony Ericsson handsets then press OK
Username: web
Password: password tap on save password and press OK It will now try and connect tap on Settings on the connection window Select manage existing connections Select O2 Mobile Web Bluetooth and press Edit Tap on Next 2 times then tap on Advanced Remove the Tick from Wait for dial tone before dialing Enter +cgdcont=1,"ip","mobile.o2.co.uk" in the Extra dial-string commands
NOTE: this doesn't appear to work with some newer handsets (eg Sony Ericsson S700i or T630) and the following should be tried;
- For Nokia handsets enter only &f in the Extra dial-string field
- For Sony Ericcson handsets enter only z in the Extra dial-string field
- The APN setting of mobile.o2.co.uk must be in the handset Tap on TCP/IP and remove the Ticks from use software compression & Use IP header compression Tap on Servers and then tap on Use specific server address and enter the
following: -
DNS: 193.113.200.200
Alt DNS: 193.113.200.201 then press OK then Finish Press OK until you get back to the today screen You should now be ready to connect.
Raymond
Wakey
PostPosted: Thu Jun 23, 2005 8:51 pm    Post subject: Reply with quote
matty_doodle wrote:
Hi Wakey,
Many thanks
Matt
Weird?
I'm using my connection ok? I did go to the tomtom website and log on as my account (email address) and new password. I registered my serial number in there as well, so perhaps you need to do that?
scoobster
PostPosted: Fri Jun 24, 2005 3:34 pm    Post subject: Reply with quote
Wakey
I to have exactly the same problem. I have registered on TOMTOM and Get the same thing. Have you tried the download option as well? I get the cannot connect to service with that as well.
My phone is a nokia 6630
lardly
PostPosted: Fri Jun 24, 2005 4:37 pm    Post subject: Plus problem Reply with quote
I had the same problem = The password is not "plus" it is whatever you have set it to on your Tom Tom account.
scoobster
PostPosted: Fri Jun 24, 2005 7:04 pm    Post subject: Reply with quote
yep sussed that. If you register on the TOMTOM site. I found that if you go to the downloads option on the 700 and login with your tomtom accoutn details it activated everything :-)
Jon
matty_doodle
PostPosted: Mon Jun 27, 2005 8:10 am    Post subject: Reply with quote
Many thanks that was "spot on" it worked a treat once I put in my login p/w. THANKS to all of you for your help :D :D
Matt Laughing
22.063 (19 Jun 24)
