ian57 Occasional Visitor
Posted: Mon Jun 20, 2005 7:50 pm Post subject: TT5 can't remember my favourite.......... |
Hi anyone else having probs after setting up home location & any favourites, then close TT in the proper way, and then they have gone!!
Have had 2 add as a POI for my home location, strange cos any POI added is saved, also any poi ticked to display get unticked when restarted as does adding warning sounds to a POI they get unticked.
Is it just me as I have'nt seen any postings yet??
Miss the options in map mode from TT3
Ipaq 2210 :D |
silversurfer Regular Visitor
Joined: May 28, 2004 Posts: 120 Location: sutton on sea .lincolnshire
Posted: Mon Jun 20, 2005 8:44 pm Post subject: post subject |
i had the same problem andwas told to make sure the sd card was set to unlock as poi are stored on the sd card , you could give that a try _________________ _________________________
chris |
Posted: Mon Jun 20, 2005 10:32 pm Post subject: |
Hi thanks for info have tried that, not had a prob with active sync changing files on Sd card so i no i can write to card.
Strange prob 4 me all user change's I make / add 2 TT are always there, .........until I have 2 restart TT, then gone, favourites, POI ticked, POI warning sounds etc.
Does anyone no where my settings r saved 2?? |
linknet Frequent Visitor
Posted: Mon Jun 20, 2005 10:53 pm Post subject: |
TTN5 stores the map settings in the map folder in a .cfg file with the same name as the map folder.
For example: The Great_Britain map settings are in the file Great_Britain.cfg in the Great_Britain-Map folder.
Maybe this file is somehow read only? |
Posted: Tue Jun 21, 2005 11:49 am Post subject: |
Spot on sorted, Many thanks Linknet. Almost getting 2 like TT5 now!!
Just 1 other prob some of my POI are saying No POI found !!
Yet they are showing up in the maps, any ideas?? |
jupiter Occasional Visitor
![](modules/Forums/images/avatars/149474498042bbe1ab9866c.jpg)
Posted: Tue Jun 21, 2005 1:16 pm Post subject: |
How do you de-select the read only box from the sd card. WHen I explore it via active-sync it is greyed out??
THanks |
Posted: Tue Jun 21, 2005 2:03 pm Post subject: |
Hi Ian - Glad that helped.
Quote: | Just 1 other prob some of my POI are saying No POI found !!
Try:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22293
I'm having this problem and can't find a solution. I originally thought my PDA had incompatibility problems but with so many people having the same fault I'm now inclined think it's a bug in the software.
You'll find some short term solutions amongst the posts but none 100% effective.
I also think that many people will have this fault and not realise, they'll just think that there are no POI's and accept the message at face value.
Roger |
Posted: Tue Jun 21, 2005 2:10 pm Post subject: |
Quote: | How do you de-select the read only box from the sd card. WHen I explore it via active-sync it is greyed out?? |
Try using a card reader, it's also a lot faster. |
Doghead Regular Visitor
![](modules/Forums/images/avatars/2106320577423e7aaca26b5.jpg)
Joined: 20/03/2003 01:56:11 Posts: 85 Location: Manchester_UK
Posted: Wed Jun 22, 2005 4:14 pm Post subject: |
I installed the TT Nav 5 with maps to SD card.
Wanting a backup I put them to CF card as well. When running TomTom Navigator 5 with only the CF card in, it doesn't remember my "Home" location, nor does it allow me to input the "Home" location.
Presumably its some data TomTom Navigator 5 added to the SD card when setting Home location, but how can I now set the Home location to work with the other CF card ? |
Posted: Wed Jun 22, 2005 4:46 pm Post subject: |
I've just jury-rigged a working solution to my "Home" problem with 2 cards, SD and CF, but surely there is an easier way. With two slot PDAs commonplace, doesn't TomTom expect people may keep a backup of map data on a second card in case the first card should fail ?
Deleted all the TomTom files from the CF card. Used a card-reader and copied the all data from original card used, the SD card, across to the desktop. Then copied those files across to the CF card.
Now got the "Home" set/select working and clickable from both cards. |
simonpearce Regular Visitor
Posted: Tue Jun 28, 2005 4:16 pm Post subject: |
I'm also having this problem on my XDA2i.
I spent ages inputting favourites to find they've all disappeared
The file isn't read only and the lock is off the card - any ideas?!
Simon |
Escargot Occasional Visitor
![](modules/Forums/images/avatars/197969901642c45a8da3f41.gif)
Joined: Jun 28, 2005 Posts: 21 Location: Buckinghamshire, UK
Posted: Wed Jun 29, 2005 12:13 am Post subject: TT5 can't remember my favourite.......... |
Can I join the club?
My TT5 running on iPAQ 4150 will also not remember Home, Favourites, POI settings etc. once it is turned off.
I checked the Great-Britain-Map.cfg as suggested and sure enough it shows up as read only, with the option to change this greyed out.
As I don't have a card reader I thought I'd be clever and I copied the file to my 'C' drive, where I could view it's properties and change them, deselected the tick in the read only box, applied the change and then copied the file back to my SD card. That didn't work!! Lo & behold it had changed back to read only again.
can anybody suggest a fix for this?? |
frank11 Occasional Visitor
![](modules/Forums/images/avatars/gallery/character_cyclops.jpg)
Posted: Wed Jun 29, 2005 12:56 am Post subject: |
Quote: | checked the Great-Britain-Map.cfg as suggested and sure enough it shows up as read only, with the option to change this greyed out.
did you delete the file from your sd card before you copied it back, other wise it will not save the changes
Frank |
Posted: Thu Jun 30, 2005 9:40 pm Post subject: |
No I didn't! But I tried again and it worked.
Thanks.. |
