Pocket GPS World :: View topic - TTN5 U/G: GPS fail Arkon and HP4150
ChasB
PostPosted: Sat Jun 18, 2005 11:55 am    Post subject: TTN5 U/G: GPS fail Arkon and HP4150 Reply with quote
Folks
Got the TTN5 u/g today, and just been spending hours Evil or Very Mad trying to get the GPS to be connected to no avail. Worked perfectly before!
-Arkon GPS Powered mount
-HP 4150
Done the settings, GPS, 4800, Com1 bit... am I missing something?
ChasB
alix776
PostPosted: Sat Jun 18, 2005 1:08 pm    Post subject: Reply with quote
try using the tomtom cable setting
device Lumia 950 xl
ChasB
PostPosted: Sat Jun 18, 2005 2:20 pm    Post subject: Reply with quote
Thanks for the idea...
But still doesn't work. Tried all sorts of things, but nothing.
I'd just feel reassured if someone had got the Arkon GPS mount to work with TT5?
I'll keep it like this for the weekend, but if no success I'll have to go back to TT3.
ChasB
alix776
PostPosted: Sat Jun 18, 2005 2:37 pm    Post subject: Reply with quote
have you unchecked the reveice all incoming beams in the ir settings and do you have anything running in the back ground ie gpsassit etc
device Lumia 950 xl
ChasB
PostPosted: Sat Jun 18, 2005 3:19 pm    Post subject: Reply with quote
Tried all of that, and no success. Must be something really silly...
ChasB
alix776
PostPosted: Sat Jun 18, 2005 4:04 pm    Post subject: Reply with quote
might be a little too silly but just a suggestion is the cradle pluged in and is the ingnition on just a thought
device Lumia 950 xl
vek
PostPosted: Fri Jun 24, 2005 12:52 am    Post subject: Reply with quote
I too cannot get the Arkon powered GPs PDA mount (cm800) to work with TomTom Navigator 5 - it worked fine with Navigator 3.
The TomTom GPS programme picks up a signal so the mount is still working but when I start the Navigator programme nothing happens despite spending hours changing baud rates etc.
Any help would be much appreciated.
ChasB
PostPosted: Fri Jun 24, 2005 8:20 am    Post subject: Reply with quote
Hi vek
I gave up in the end. Admitted defeat. I tried everything, and I am supposed to be a highly qualified electronic engineer of more years experience than I care to remember!
In the end, I concluded that the output of the Arkon GPS mount is just not being recognised by the TT5 s/w. I have now bought a bluetooth GPS. Not an ideal solution, as I cannot now get Traffic as the BT is now occupied to the GPS, and can't talk to the mobile at the same time!
Would be really interested if anyone has solved this and got this combination to work.
Charles
vek
PostPosted: Fri Jun 24, 2005 6:48 pm    Post subject: Reply with quote
Thanks Charles - I guess I should give up to!
Which BT GPS did you buy and do you still use the Arkon mount - i notice you can use it to charge the BT GPS?
I am thinking that I should buy a TomTom BT GPS to ensure it actually recognises it!
Any advice would be much appreciated.
Kev
ChasB
PostPosted: Sat Jun 25, 2005 7:08 am    Post subject: Reply with quote
Kev
I bought a Globalsat BT-338 from a UK supplier on Ebay for £100. Works well being charged by the Arkon mount (made up a small lead courtesy of Maplin). And the other advantage is that it can be used whilst walking!
I see you can get the TT GPS for a little cheaper so that may also be an option.
Charles
ChasB
PostPosted: Tue Aug 02, 2005 9:50 am    Post subject: Note for the record Reply with quote
Upgraded to 5.1 and it now works with the Arkon mount...
settings wired GPS, 4800 Baud, COM1.
ChasB
22.094 (25 Sep 24)
