iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Tue May 24, 2005 2:01 pm Post subject: |
have you paired the device through bluetooth manager and set up a serial port profile?
Ian _________________ -----------------------------------------------------------
TTN6.03 tomtom 7.xx (one) |
adamforman Occasional Visitor
Posted: Tue May 24, 2005 2:08 pm Post subject: Paired |
I have paired the unit successfully
When i check the status it shows conncected
and when i select active connections and view the outgoing conncections it shows SPP Slave
any suggestions ? |
Posted: Tue May 24, 2005 2:21 pm Post subject: |
in tomtom gps screen - GPS tab
select NMEA 0183v2 9600
select Bluetooth serial port com ???
??? being the number of the incoming bt serial port - if you are unsure which is which try both until;.
on the STATUS tab
you see dots running from sat icon to pda icon
then you should see the red bars on the tomtom display.
HTH
Posted: Tue May 24, 2005 2:37 pm Post subject: madness |
I haves spend the last few hours doing exactly what you said... even beofre i made a post !!! to this forum.. its all working no idea what i did differently !!! |
Posted: Tue May 24, 2005 2:43 pm Post subject: |
great news!
glad its working now
Posted: Tue May 24, 2005 5:52 pm Post subject: ARGGHH |
Thanks for your help on this, I have the little dots running across from the sat to the handheld on the tomtom gps and the time is displaying, how long does it normally take for all the data to take in to effect and display details like N & E and MPH???
any help would be appreciated |
Posted: Tue May 24, 2005 6:33 pm Post subject: |
do you have a clear view of the sky?
The first time you use it it can take half an hour to download the info as the sats come into view - after this it should be less than a minute.
I would leave it outside away from building etc for 15 + minutes and you should get a fix.
Are there any grey bars showing - these will turn red when a fix is made?
Posted: Tue May 24, 2005 7:20 pm Post subject: Thanks |
Ahh I understand now, i wish there was a proper manual with this unit, its on a PDF but nothing tells you about this.
I have a few grey bars and Im in a flat at the moment, I will take this with me tonight and leave it on to see if it works
Thanks for all your help |
Posted: Wed May 25, 2005 11:02 am Post subject: this is fun... |
ok so now I have read all the posts all over the net, I have upgraded the tomtom gps componet this has changed the icon , it seems to work better . I have also installed the app : VisualGPSce which shows me what sats are in view and helps tons. I did try and install the latest TOMTOM GPS that you can download from this site BUT after installation it asks me to install a proper version of tomtom and cant find maps... so i have taken it back to GPS version 3.07 rather than Version 4. any news on the newer version of GPS out there that works on all pocket pcs ! |
Posted: Wed May 25, 2005 1:50 pm Post subject: |
version 3.07 is the latest version that works on all pocketpc's!
stick with it until ttn5 comes out - which will come with a revised gps section. _________________ -----------------------------------------------------------
tex Occasional Visitor
Posted: Sun Jun 05, 2005 5:48 pm Post subject: |
I rcvd this receiver the other day. It has worked a total of two times for me. My current problem is that I get the flashing red light (sat lock) and I have it successfully paired to my laptop, despite these two facts, I don't show any data crossing the line. I've tried numerous programs (terminal, visualgps, visualgpsxp) to try to see the data, but no luck. MS Autoroute 2005 says it can see the port, but that there's no gps data. Does anyone out there have any clues?
Dell Inspiron 700m
Hama usb Bluetooth Adapter (class 1)
GPT-600 Bluetooth Receiver (repackaged BT77) |
n7610 Occasional Visitor
Posted: Wed Jun 08, 2005 7:41 pm Post subject: Nokia 7610 and Bt 77 |
ianrickycarmichael wrote: | i am having the same problem as brandi. have paired a bt 77 with nokia 7610 succesfully and am using tom tom mobile software. tom tom is saying its waiting for a valid gps signal and gps device is displaying a steady flashing red light on left and a steady flashing blue light on right -every 3 secs.could it be sonmething to do with installing the drivers to the phone incorrectly or is it something else-help please. |
ianrickycarmichael, do you manage to get it work? |
gshaw Occasional Visitor
Posted: Mon Jun 13, 2005 9:39 pm Post subject: |
So are these 2 the same device just a different case?
I really don't know what to do - it seems a risk with these but I can't afford like 150 quid from a shop - would ppl recomend these to use with Route 66 and Nokia 7610??
Cheers,
Gerrard |
111hhh111 Occasional Visitor
Posted: Sat Jun 18, 2005 1:26 pm Post subject: |
Sorry if this has been asked before, but does anyone know of a replacement battery for the Unit. I think mines on the blink. Thanks in advance. |
Spark1e Banned
Posted: Sat Jun 18, 2005 2:04 pm Post subject: |
If you've got the BT-77 (the 2nd picture above) then a Nokia 6230 battery will fit. Don't know about the other one sorry, but they do look the same ?? |
