ChasB Occasional Visitor
Posted: Sat Jun 18, 2005 11:55 am Post subject: TTN5 U/G: GPS fail Arkon and HP4150 |
Folks
Got the TTN5 u/g today, and just been spending hours trying to get the GPS to be connected to no avail. Worked perfectly before!
-Arkon GPS Powered mount
-HP 4150
Done the settings, GPS, 4800, Com1 bit... am I missing something?
ChasB |
alix776 Pocket GPS Moderator
Posted: Sat Jun 18, 2005 1:08 pm Post subject: |
try using the tomtom cable setting _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sat Jun 18, 2005 2:20 pm Post subject: |
Thanks for the idea...
But still doesn't work. Tried all sorts of things, but nothing.
I'd just feel reassured if someone had got the Arkon GPS mount to work with TT5?
I'll keep it like this for the weekend, but if no success I'll have to go back to TT3.
ChasB |
Posted: Sat Jun 18, 2005 2:37 pm Post subject: |
have you unchecked the reveice all incoming beams in the ir settings and do you have anything running in the back ground ie gpsassit etc _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sat Jun 18, 2005 3:19 pm Post subject: |
Tried all of that, and no success. Must be something really silly...
ChasB |
Posted: Sat Jun 18, 2005 4:04 pm Post subject: |
might be a little too silly but just a suggestion is the cradle pluged in and is the ingnition on just a thought _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
vek Occasional Visitor
Posted: Fri Jun 24, 2005 12:52 am Post subject: |
I too cannot get the Arkon powered GPs PDA mount (cm800) to work with TomTom Navigator 5 - it worked fine with Navigator 3.
The TomTom GPS programme picks up a signal so the mount is still working but when I start the Navigator programme nothing happens despite spending hours changing baud rates etc.
Any help would be much appreciated. |
Posted: Fri Jun 24, 2005 8:20 am Post subject: |
Hi vek
I gave up in the end. Admitted defeat. I tried everything, and I am supposed to be a highly qualified electronic engineer of more years experience than I care to remember!
In the end, I concluded that the output of the Arkon GPS mount is just not being recognised by the TT5 s/w. I have now bought a bluetooth GPS. Not an ideal solution, as I cannot now get Traffic as the BT is now occupied to the GPS, and can't talk to the mobile at the same time!
Would be really interested if anyone has solved this and got this combination to work.
Charles |
Posted: Fri Jun 24, 2005 6:48 pm Post subject: |
Thanks Charles - I guess I should give up to!
Which BT GPS did you buy and do you still use the Arkon mount - i notice you can use it to charge the BT GPS?
I am thinking that I should buy a TomTom BT GPS to ensure it actually recognises it!
Any advice would be much appreciated.
Kev |
Posted: Sat Jun 25, 2005 7:08 am Post subject: |
Kev
I bought a Globalsat BT-338 from a UK supplier on Ebay for £100. Works well being charged by the Arkon mount (made up a small lead courtesy of Maplin). And the other advantage is that it can be used whilst walking!
I see you can get the TT GPS for a little cheaper so that may also be an option.
Charles |
Posted: Tue Aug 02, 2005 9:50 am Post subject: Note for the record |
Upgraded to 5.1 and it now works with the Arkon mount...
settings wired GPS, 4800 Baud, COM1.
ChasB |
