Pocket GPS World :: View topic - BT338 only works with TT3.07GPS
Gando
PostPosted: Tue Jun 14, 2005 4:47 pm    Post subject: BT338 only works with TT3.07GPS Reply with quote
I recently purchased an ipaq 4700 and felt the BT338 would complement this. I used the pair with TTNavigator 3 and gps 3.07 and found they worked perfectly. I was extremely pleased with my selection.
I then upgraded to TT5 and found the GPS could not be found - similar as per several of the other links in the forums. I have tried all the suggestions given in these forums even the one where a registry entry is altered, but to no avail.
I decided to reformat the ipaq – performed a hard reset and then only loaded TT5 and the BT338 software (GPS info) – still no GPS with TT5 and after trying the supplied software with the BT338 where I start GPS on com8 serial8 at 38400 baud the blue light on the GPS starts flashing faster as per having a connection but when I go to GPS info there is no information.There is a similar reaction with TT5 .
I then reloaded TT GPS 3.07 and found that straight away everything was ok. 5 to 6 satellites found and logging. But this is no use for TT5. I now don’t know whether it is the IPAQ the GPS or the software at fault. Has anyone any more suggestions to try????
dickdastarley
PostPosted: Wed Jun 15, 2005 5:50 pm    Post subject: Reply with quote
i don't have any sugestions but i do know bt338 works with tt5.
this is my setup exept mine is on a palm t3 not a ipaq 4700.
dondee123
PostPosted: Fri Jun 17, 2005 9:43 am    Post subject: connectivity problems with tomtom 5 and bt-338 Reply with quote
I own a copy of tomtom 5, XDA2S and a global sat bt338 GPS; I am having similar problems in connecting the bt338 to tomtom. I think it could be bug in the tom tom software since prvious versions of it work well. I hope TOMTOM get there finger out and resolve the issue.
Crying or Very sad
SimonCatlin
PostPosted: Fri Jun 17, 2005 9:46 am    Post subject: Reply with quote
Mine is working, but I am using GPSGate to avoid any other ocnflict inside TomTom Nav 5.
In addition I have selected other wired devices, select the com port and then select the baud rate of 38400.
If I get chance today I will exclude GPSGate from the equation and test it without.
Simon
iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk)
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Gando
PostPosted: Fri Jun 17, 2005 11:53 am    Post subject: Reply with quote
Have managed to make everything work with the simplest of tasks - I saw this in another forum and thought I would give it a try - Remove the battery from the BT338 for 2 minutes!!! On reinserting everything came to life - TT5 works selecting the other bluetooth GPS and com port 8 which is the correct way. GPS info now also works. I still dont know why I got TT3 GPS 3.07 to work in its previous state so in case I am just lucky I am keeping everything crossed
NU2GPS
PostPosted: Mon Jun 20, 2005 8:39 pm    Post subject: Reply with quote
I don't know if this will work for you, but I have a SPV M2000 which is based on the XDA2S, and I had the same problems you are having. find out what your out going com port is then.
In Tom Tom 5 select other cable NMEA GPS NOT Other Bluetooth GPS, set baud to 38400 and choose Com Port ? (whatever your out going port is).
I hope this info can help.
Wink
23.052 (14 May 25)
