Pocket GPS World :: View topic - TTN5 and POI's
TTN5 and POI's
jpfrost
PostPosted: Thu Jun 16, 2005 10:03 am    Post subject: TTN5 and POI's Reply with quote
With TTN3 I could simply click the "Navigate To" button, select a POI - say "Cash Dispenser" and it would show me where the nearest one was. With TTN5 when I do this I get a "No POI found!" message. If I display the "Cash Dispenser" icons on the Map View they do appear - I just cannot navigate to them!
If I try the same with Custom POI's (e.g. the pocketgps speed camera files) it works fine and shows me a long list of points i can navigate to.
Is this a problem with my setup or problem with the software?
Thanks.
Neil F
PostPosted: Thu Jun 16, 2005 10:40 am    Post subject: Reply with quote
Several people are seeing this problem. See here:-
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=22293&highlight=
Neil
sooty
PostPosted: Thu Jun 16, 2005 10:46 am    Post subject: Reply with quote
This subject has been discussed in previous threads.
It would appear that there is a problem with some of the the built in POI's supplied with version 5.
I am currently using the POI file from version 3 as a temporary solution which seems to be working ok.
I emailed tomtom about this 3 days ago but have not yet received a response.
Sooty
linknet
PostPosted: Thu Jun 16, 2005 12:26 pm    Post subject: Reply with quote
From some of the other threads this "No POI found" problem is causing TTN5 to crash to desktop.
This seems to be more common on PDA's running WM 2003 SE.
The fact that TTN5 crashes masks the origin of the fault, which occurs when trying to access a POI which would have given a "No POI found" on other PDA's. It can also occur during browsing the map with the problem POI's enabled since TTN5 is again trying to access the missing POI's.
Roger
22.055 (29 May 24)
