Pocket GPS World :: View topic - TTN5 & BT-338 GPS Reciever
Goto page Previous  1, 2
mixer25
PostPosted: Wed Jun 15, 2005 9:05 pm    Post subject: THIS WORKS! TOMTOM 5 & GPS Reply with quote
If you do the following this allowed me on an iPAQ 4150 and TOMTOM 5 to Connect to the GlobalSat BT-338 no problem...
Delete ALL connections...
For automatic BlueTooth connection please follow these instructions:
Install a registry editor, for example PHM Regedit http://www.phm.lu/Products/PocketPC/RegEdit/
After installation, navigate it to \HKLM\Software\Widcomm\BtConfig\AutoConnect\0008. 0008 might be another number, it's a reference to your Bluetooth COMport's number.
Under 0008, create a new DWORD key called BtBrowserEnabled, and give it the value 0 (zero).
Close the registry editor and soft-reset your PDA.
Open the Bluetooth Manager and connect to your GPS receiver. If all goes well that should have been the last time.
By the way, I couldn't get PHM Edit to install (I see others complaining also), so I found another good registry editor called BitsInside RegEdit
Then Pair Ipaq to BT338, then use "Other Bluetooth GPS setting" and Serial Port 6 (in my case)...
Then Connect!
It works! you will probally have to mess about a bit anyhow, but good luck
Page 2 of 2
22.101 (03 Oct 24)
