Pocket GPS World :: View topic - TTM 5 As A Camera Warning Only
witchnut
PostPosted: Mon Jun 13, 2005 9:08 pm    Post subject: TTM 5 As A Camera Warning Only Reply with quote
When I'm driving around my local area I'd like to have POI warnings (cameras) but not have turn-by-turn directions, or the need to "navigate to". Is there a mode I can use to achieve this or something similar basically just to have the TTM 5 left switched on but not on a specified route?
Witchnut
pcb007
PostPosted: Mon Jun 13, 2005 9:24 pm    Post subject: Reply with quote
Just set up Tom Tom to warn you when approching the cameras, but at the final stage ensure that only warn on route is unticked. Then you will get warnings without needing to put a route in.
aliendad
PostPosted: Tue Jun 14, 2005 11:04 am    Post subject: Reply with quote
i know your question has been answered, but if this is of use to you as well,
go into preferences: 66653 and set the display to turn off map at a selected speed.
hobo
PostPosted: Tue Jun 14, 2005 3:19 pm    Post subject: Reply with quote
Or you could just use Cameraware. Not tried it myself but it might suit your needs.
http://www.modaco.com/index.php?showtopic=201984
aliendad
PostPosted: Tue Jun 14, 2005 5:58 pm    Post subject: Reply with quote
depends on the phone you have, wont work on symbian phones
witchnut
PostPosted: Wed Jun 15, 2005 12:31 am    Post subject: Reply with quote
My question hasn't been answered really!. For some reason, if I just leave the phone running TTM 5 with no route specified it seems to assume a route like "home" and give me directions (which isn't what I wanted), also with no route specified the GPS fix seems less certain, the map rotates +/- 30 deg and sometimes shows I'm driving in the fields! What am I doing wrong. Will people giving advice please confirm that it works on their phone + gps, rather than just state what they think should work.
Witchnut
erniew
PostPosted: Wed Jun 15, 2005 4:40 am    Post subject: Reply with quote
i tried this on my system and it just follows whatever road you are driving along it is not so accurate especialy around junctions as it is reacting to where you go instead of telling you where to go
make sure you have cleared the route from then it should not try to direct you
i had no probs with this
the camera alerts still sound as usual
hope this helps
erniew
aliendad
PostPosted: Wed Jun 15, 2005 6:54 am    Post subject: Reply with quote
i have ttm5 with 6600, if i put ttm5 on without a route it will show me where i am traveling,
as someone has already said make sure you have no route in memory.
it sounds as if your gps receiver is get a poor signal
check the gps status screen to see the signal your getting
and back to your first question, camera's work whilst i'm driving without having a route planned.
pcb007
PostPosted: Wed Jun 15, 2005 8:06 am    Post subject: Reply with quote
Your question has been answered. If you untick only warn on route you will get your warnings without having a route planned, i use it everyday and it worls fine. I suggest you check what the other guys are saying.
23.054 (28 May 25)
