Pocket GPS World :: View topic - TT5 - Navigate To Contact
SpeedCam
PostPosted: Fri Jun 10, 2005 9:09 pm    Post subject: TT5 - Navigate To Contact Reply with quote
Is anyone else experiencing problems using the 'Navigate to' in their contacts..
I receive a message saying, Found problem analyzing the contacts address. Please verify....
I press Ok, and the contact is displayed, with street city & postcode correct, pressing Ok again generates a 'failed to start error'
I'm now using a non pirated copy...
PostPosted: Sat Jun 11, 2005 3:50 am    Post subject: Reply with quote
The address search function is extremely particular how you write the address. In 99% of all cases you will write it differently than what TomTom expects, leading to these error messages. I would say the feature is even more useless than it was already in TTN3.
Palendrone
PostPosted: Sat Jun 11, 2005 11:59 am    Post subject: Reply with quote
anyone care to give us an example of how our contacts addresses should look?
Peter Kessler
PostPosted: Mon Jun 13, 2005 9:53 pm    Post subject: Reply with quote
I don't seem to be getting any contacts integration at all, although the Contacts Navigatioon folder is present, and has files in it. Any advice?
PostPosted: Mon Jun 13, 2005 10:05 pm    Post subject: Reply with quote
it's not a folder. You go to your Pocket Contacts (no, Pocket Informant etc are not supported) tap and hold a contact and then select "Navigate to" - in the following form you can try your luck at an address that TomTom actually understnds.
Peter Kessler
PostPosted: Mon Jun 13, 2005 10:40 pm    Post subject: Reply with quote
Yes, that's exactly what I'm doing. But the 'Navigate to...' option is not there. (Incidentally, TTN5 has installed perfectly in every other way.)
Are you meant to do some sort of one-off indexing?
barryd
PostPosted: Mon Jun 13, 2005 11:19 pm    Post subject: Reply with quote
In Contacts, edit the contact and tap the little arrow pointing down to the right of the address. This shows the Contacts address fields, which map onto the TomTom address fields like this in the UK at least:
Street -> Street and Number
City -> City
State
Zip -> Postal code
Country
On the ones I've tried, the data is typically in the wrong fields in Contacts, as Lutz said. Often I have two lines for Street (a building then a street, or a street then a village) which TomTom doesn't like.
Your options are to work through your contacts one by one, editing them into the shape that TomTom wants; or just create POIs in TomTom for the ones you want. I tried it for a bit in TomTom 3 and settled on the latter approach.
Barry Davies
Peter Kessler
PostPosted: Mon Jun 13, 2005 11:31 pm    Post subject: Reply with quote
Thanks, Barry, but the problem here is not TTN's failure to comprehend my data; it's the fact that it has not added the navigation option to Contacts at all.
In fact, even as I write this, a box has popped up on the contacts screen, reading:
Notification error
Cannot execute \\.\Notifications\NamedEvents\EventWakeUpTomTom
The mystery deepens...
PostPosted: Tue Jun 14, 2005 12:05 am    Post subject: Reply with quote
Peter, the notification error is unrelated.
Try to reinstall the PIMAddin.CAB
Peter Kessler
PostPosted: Tue Jun 14, 2005 12:32 am    Post subject: Reply with quote
OK - but where is that? On the TTN CD?
Peter Kessler
PostPosted: Tue Jun 14, 2005 12:43 am    Post subject: Reply with quote
Right, I copied the .cab file onto my ipaq, then ran it. It said the application was already installed, and I confirmed that it should re-install. But... no difference afterwards.
I'm on a 3970 running PocketPC 3. To be honest, I can live without this feature, but it's worrying. And am I the only one?
Halfpiste
PostPosted: Tue Jun 14, 2005 6:07 am    Post subject: Reply with quote
No, my contacts integration on 3970 doesn't work either
tgarcez
PostPosted: Thu Jun 16, 2005 11:01 pm    Post subject: Contacts navigation Reply with quote
I have likewise tried all of the above - and no joy - still no option to "navigate to..." - either directly or via tools menu!?!?!
ANy ideas why this may be?
iPAQ 5450 (PPC 2002)
TTN 5
BTGPS (TT3)
Lurch_uk
PostPosted: Tue Jun 21, 2005 9:44 pm    Post subject: Reply with quote
I have 5500 & TTN 5
I was experiencing exactly the same problem, but reading through the forum I came to the conclusion copying and installing the PIMADDIN was the only option.
I copied both the CAB and the ini file to the Navigator directory on my PPC and clicked on the CAB on my PPC ..... Navigate to now works :D
Peter Kessler
PostPosted: Tue Jun 21, 2005 10:31 pm    Post subject: Reply with quote
Nope, not for me.
23.012 (08 Jan 25)
