Pocket GPS World :: View topic - Running European and U.K. areas at the same time?
Viper
PostPosted: Thu Jun 09, 2005 11:29 pm    Post subject: Running European and U.K. areas at the same time? Reply with quote
I have had copilot U.K. registered area for a while now.
If I were to buy an European upgrade, as long as I had enough sd card space would it be possible to have installed and running at the same time both U.K and European maps, without having to download one then the other when each area is needed.
Thank You
Steve
kartracer
PostPosted: Thu Jun 09, 2005 11:36 pm    Post subject: Reply with quote
Yes. You can even do cross Channel routing.
Kam
Viper
PostPosted: Fri Jun 10, 2005 3:25 pm    Post subject: Reply with quote
Thanks Kartracer,
How did you upgrade yours? I have tried ringing Alk up via the phone number which was on the registration number card supplied with copilot 5 but the line is dead!
Steve
PostPosted: Fri Jun 10, 2005 4:18 pm    Post subject: Reply with quote
Number shouldn't be dead, the number's been pretty busy though the last few days. What number do you have ? We have an 0207 and an 0845 number. The 0207 404 4222 is the one that most people use.
Viper
PostPosted: Fri Jun 10, 2005 9:53 pm    Post subject: Reply with quote
Yes thats the number I tried Dave, all I had was a silent line.
Steve
PostPosted: Sat Jun 11, 2005 1:42 pm    Post subject: Reply with quote
Steve, not sure why you received that. Which telco were you using ? Perhaps it's a problem routing calls.
I called the support line 4 times yesterday, once I did get an engaged tone over lunch because we had a high level of calls stacked in the queue, but a quick redial and I got placed onto the end of the hold queue.
We have had some problems with our phone system, more so dialling out to mobiles, so if you are continuing to have a problem, please let me know and I will investigate this with our service company.
If you can let me know what dates and times of day you've tried and also which telephone company you are using (and if you're routing your calls through a low cost provider, which company you are using).
PostPosted: Sat Jun 11, 2005 1:45 pm    Post subject: Reply with quote
You may/may not have noticed, but late Friday evening I've managed to get the new online support system in-place. This will be a huge improvement for contacting support, and if you log a call via the web or send us an email to ukcustservice@alk.com and include your contact details we'll call you back on your preferred number.
Viper
PostPosted: Sun Jun 12, 2005 2:02 pm    Post subject: Reply with quote
Thanks Dave will do that!
Maybe you can help me first Dave? I am looking to upgrade my copilot to the European area's, but I can afford to wait a while before buying as I am not going on holiday yet. Is copilot 6 coming out soon and if so will there be a cheaper option to upgrade from 5-6 for existing users, if this is the case I might wait to buy copilot 6 both uk and Europe areas at the same time, if not I will just upgrade my existing copilot 5 to the European area's and forget version 6
Steve
PostPosted: Mon Jun 13, 2005 6:26 pm    Post subject: Reply with quote
There is no release date for any new versions of CoPilot software, we're still working on v5 at present.
Bazzer
PostPosted: Tue Jun 14, 2005 9:12 am    Post subject: Reply with quote
Thats strange then Dave. As last time I was speaking with your office (S.Mistry - about 3 weeks ago) about still unresolved issues with CP5, I mentioned the forthcoming release of CP6 and the hope that this release would fix the many problems with CP5.
I was advised that the proposed release date for CP6 was September this year ?? True or not ??
Notwithstanding the above, I was not offered any solution to any of the issues that I have.
Baz
Crying or Very sad
PONDEROUS
PostPosted: Wed Jun 15, 2005 10:00 pm    Post subject: Reply with quote
As I previously said elsewhere on the forum, I too was told that CP 6 would be out in September.
Please clarify the situation for us all, Dave and ALK.
PostPosted: Thu Jun 16, 2005 6:30 pm    Post subject: Reply with quote
Assumptions were being made by some of my support staff that the release would be due out in September because it was approx 1 year ago to that date when CPL5 was released.
I can confirm that currnetly there is no release date for v6 at present.
22.101 (03 Oct 24)
