Pocket GPS World :: View topic - GM-270 CF card disassembly
philip4242
PostPosted: Sat Jun 11, 2005 6:49 pm    Post subject: GM-270 CF card disassembly Reply with quote
Following the theft of my Medion PDA/GPS, I'm bringing back into use my Toshiba E740 PDA + Holux GM-270 CF GPS.
However, I need to use the external aerial to receive enough satellites to get a 'lock'.
The problem is that I need to hold the aerial connector at the CF card end in a certain position for the signal to be acceptable.
If I let go, the signal disappears - so I suspect a 'dry' joint on the connector on the card.
So my question is - How easily does the front cover come off the top part of the card ?
And is that the best way to allow access to the solder connections for the aerial connector ?
I can feel that the very top edge is not glued or welded, but I think the sides MAY be.
I obviously don't want to risk damaging the unit for what should be a simple repair.
The soldering itself holds no terror for me - I've been building and repairing electronic devices (including some with surface mount components) for many years.
Does anyone have any tips ?
Getting older and more senile by the minute !
Philip
22.062 (12 Jun 24)
