cbx200 Occasional Visitor
Posted: Thu Jun 09, 2005 8:24 pm Post subject: tomtom 5 and wired receiver CF |
I have an HP 2210 with tt5 and Haicom CF HI 302-CF
I have used older versions of tt without problems with the same equipment.
Regarding the satellite receiver, I have a couple of issues/problems:
a) The tt5 recognises the Haicom and it shows as one of the possible receivers under Haicom CF GPSin the tt5. I get satellites but the signal is not strong enough to make the software functioning I have tried in the outside in different locations, where I wouldnt have had any problem with previous tt.
I had the bad at 1200. Can this be the problem?
I get a mesage : signal not valid
b) I have to start the GPS receiver manually everytime, the soft would not recognise it automatically when I start the program (tt5). is there a solution for this? previous tt would recognise the receiver automatically.
thanks |
lbendlin Pocket GPS Staff
Posted: Fri Jun 10, 2005 1:40 am Post subject: |
set the receiver to 38400, and then in TTN5 select "Other BT receiver" - see if that helps.
CF is not considered wired - that's only for COM1: (serial) connections. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Jun 10, 2005 7:20 am Post subject: |
thanks for the reply , but it does not work setting it up as BT |
Posted: Fri Jun 10, 2005 1:15 pm Post subject: |
Well, tough luck then. Have you reported it to TomTom? _________________ Lutz
gasser Occasional Visitor
Posted: Fri Jun 10, 2005 1:58 pm Post subject: |
I have the same kit
Just set up wired receiver, at 1200, using CF port.
Then you have to WAIT until the receiver has locked on. Play with TomTom for a bit to make sure. Then just exit. Nest time it will detect receiver after a few seconds! |
Posted: Fri Jun 10, 2005 2:22 pm Post subject: |
1200 sounds a bit low. Try at least 4800 _________________ Lutz
Posted: Fri Jun 10, 2005 7:32 pm Post subject: |
ok it works now with 4800 thks |
