Hannibal Occasional Visitor
Posted: Tue Jun 07, 2005 5:21 pm Post subject: TT5 & Navman Jacket.....help please! |
I have a Navman jacket GPS reciever and TT5. I can't get a signal using tomtom, despite getting a fix using the 'GPS info' program that comes with it, tomtom does pick up the UTC though. Do I need any other drivers (navman 3.1.6 serial driver installed) to get it working? Your help is appreciated.
H |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Tue Jun 07, 2005 5:54 pm Post subject: |
Hmm, I used my Navman sleeve with TTN5, with the 3.1.6 driver installed on my iPAQ. I chose "Other cable GPS" and the top option, I think, was Navman Driver. _________________ Tim |
clem Regular Visitor
Joined: 15/10/2002 20:16:43 Posts: 86 Location: United Kingdom
Posted: Tue Jun 07, 2005 6:09 pm Post subject: |
What Hannibal said is correct, but you will need to set the baud rate to 57600. |
Posted: Tue Jun 07, 2005 7:07 pm Post subject: |
Tim Buxton wrote: | Hmm, I used my Navman sleeve with TTN5, with the 3.1.6 driver installed on my iPAQ. I chose "Other cable GPS" and the top option, I think, was Navman Driver. |
i have done this, but it still doesn't work. I have a 3000 series sleve IIRC. I'm going to try re-installing the software to see if that makes any difference - glad to know it 'should' work!
H |
Posted: Tue Jun 07, 2005 9:01 pm Post subject: |
The re=install hasn't worked I forgot to say, the message I get is 'no valid gps signal' any ideas?
H |
Posted: Tue Jun 07, 2005 11:01 pm Post subject: |
No valid GPS Signal means that the sleeve can't see any satellites. Have you taken it outside for a good look at the sky? The Navman 3000 isn't as sensitive as the newer SE model. _________________ Tim |
Posted: Wed Jun 08, 2005 8:04 am Post subject: |
Tim Buxton wrote: | No valid GPS Signal means that the sleeve can't see any satellites. Have you taken it outside for a good look at the sky? The Navman 3000 isn't as sensitive as the newer SE model. |
...and don't I know it - I'm planning to upgrade to a SiRFstar III next month & new PDA (but not yet decided on which ones). I have had the reciever in the car on the way to and from work the last couple of days (about 30-40 min trip) and no luck. It does get a 3d fix using either the navman or tomtom gps info programs, that's why I think it may be a driver issue.
H |
gav28 Occasional Visitor
Posted: Wed Jun 08, 2005 9:28 am Post subject: |
I setup a friends Ipaq 3950 with the Navman Jacket last night, with TTN5. Works a treat.
The key things to do are:-
a) Make sure you install the Navman 3.1.6 drivers
b) Install TTN5
c) Select Other GPS device when selecting the GPS device within TTN5
d) Make sure the baud rate is 57600
e) Select Navman Driver as the port
f) Take the unit outside for a lock, we had to wait several minutes before the "No Valid GPS Signal" message was updated to show satellite information!!
I hope this helps?
cheers |
Posted: Wed Jun 08, 2005 10:09 am Post subject: |
Good advice, Gav. Put your iPAQ & sleeve outside and leave it on to get a fix. It can take forever if you are trying to get a fix whilst moving. _________________ Tim |
Posted: Wed Jun 08, 2005 2:22 pm Post subject: |
Tim Buxton wrote: | Good advice, Gav. Put your iPAQ & sleeve outside and leave it on to get a fix. It can take forever if you are trying to get a fix whilst moving. |
OK, it's sat halfway down the garden, plugged into the mains waiting for something to happen. It has got a fix using applications other than TTN5 when on the move, which makes me think that it may be a discrepacny with TTN5. TTN3 never saw satelites (i.e. the bars at the bottom never lit up) but could still get a 3d fix. The GPS info program can too. I have a feeling 'cos there are officially no satelites in view, TTN5 is ignoring the fix
H |
Posted: Wed Jun 08, 2005 5:22 pm Post subject: |
I now have my setup working - thanks for all your help. Having left it in the garden to no avail, I went to visit a friend and left it in the car for an hour or so - to my suprise, there was a fix when I returned - not only that, but satellites were also showing in the bars at the bottom! lets hope it doesn't take that long to get it's next fix! Incidently I now have navman and ALK drivers showing in the gps info window- previously this just showed navman, I'm not sure if this is what has helped, does anyone know?
Cheers guys,
H |
Posted: Fri Jun 10, 2005 10:46 am Post subject: |
After a few days of trying to get another fix, I have failed I 'saw' one sat yesterday, but that's been it. Unfortunately after my previous 'fix' I accidently did a reset without closing tomtom. again other applications get a fix within a minute or two just tomtom takes forever to not get one. Could someone else with this setup give me a guide as to how long it takes for them to get a fix please. Oh and I'd be interested to know their reciever SW version.
thanks
H |
Posted: Fri Jun 10, 2005 12:13 pm Post subject: |
Hannibal,
My father-in-law has a similar setup:
-IPAQ 3970 with windows mobile 2003 Prod Rev Level 2.5 Rom version 4.00.08 ENG + Bluetooth driver patch
- NAVMAN sleeve Receiver SW Ver 2.1.1M01325 Navman Ipaq 2.1.2
- TT Navigator 5
In TomTom Navigator Settings - GPS Status select 'Other Cable NMEA GPS'
GPS baud rate = 57600
Navman GPS
It will show No valid GPS signal for a while but you should spy some figures appearing in the sat columns (will go red when fixed).
Do a soft-reset if not locking. Failing that you could try a hard reset and start from scratch (which is what we did).
Hope that helps ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
Rutger Occasional Visitor
![](modules/Forums/images/avatars/gallery/simpsons10.jpg)
Posted: Fri Jun 10, 2005 7:26 pm Post subject: |
I can heartily agree with all comments made by Hannibal. I have an iPaq 3870, Windows mobile 2003, Navman Jacket and TomTom Navigator 5.
I had no problems with TTN3, GPS fix and re-acquisition times were standard for the Navman Jacket. After upgrading to TTN5 (I actually removed TT3 and maps, reinstalled Navman serial driver 3.1.6 and installed TTN5) GPS fix times have been nothing short of a joke. Immediately after upgrading, I went outside and got a fix within 5 minutes. The day after it took a whole 15 minutes sitting in the car waiting for a fix, watching at least 6 or seven grey bars jumping around near maximum but nothing. I gave up eventually and drove 90 miles watching the GPS status window until it eventually got a fix.
When TTN5 is locked on it seems reasonably solid but after stopping at a service station today it lost the fix sat on the forecourt and took another 25 minutes and 30 miles to re-acquire. This is simply not good enough. I know there has been a major re-write of the GPS code but why does it take so long?
I can run the old TomTom GPS app. and it will get a fix in seconds, but not when TTN5 tries. I would have liked to try connecting directly to the COM port that the Navman Serial driver creates (COM 6 in my case) but it doesn't show COM 6 in the GPS config window just COM 3. I am forced to use the 'Navman Driver'.
Any suggestions? |
naza Occasional Visitor
![](modules/Forums/images/avatars/3e03eea64066cd0a1f3cd.jpg)
Posted: Wed Jun 15, 2005 8:08 am Post subject: |
yes heres a few:
Buy a new GPS!
I recommend the arkon powered GPS mount (CM805)
While your at it why dont you buy a hx4700 as well!
oh and dont forget to treat yourself to a raptor that you know you want whilst you have your credit card out!
Neil _________________ Naza
System Config:
HP HX4700
WM2003
TTN 5 PDA and TT Mobile
Tomtom Wireless GPS
Sandisk 1.0GB SD
Nokia 6680 on vodafone
E1000 on "Three"
(Not a gadget freek honest ;-) |
