SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Thu Jun 09, 2005 8:51 pm Post subject: TomTom V5 - Plus Maps & Traffic... |
Received my upgrade today, and the map CD's seem to have to versions of the maps, a standard version and a Plus version, does anyone know the difference. The basic only does not appear to be a cut down version as the UK standard was about 130Mb and the UK Plus over 200MB, it not the postcodes either.
Also the little round icon in the top right corner indicates traffic updates, green is work and upto date, amber meas there is more upto data info available. Even though I have my traffic set to update every 15 minutes the icon appears to stay amber a long time, any ideas?
Cheers |
vlak Regular Visitor
Posted: Thu Jun 09, 2005 9:10 pm Post subject: |
The PLUS map integrates Major Roads of Europe (MRE). Using the PLUS map, you can navigate to any other country in Europe without having to swap from Great Britain map to MRE. Once in that other country you would then need to swap to that country's map for a detailed map. |
julianbarker Lifetime Member
Posted: Thu Jun 09, 2005 10:19 pm Post subject: |
Arguably it is easier to to it the other way round - it is beter to ave the detail of the final destination when yo uset out rather than change - unless you have no idea how to get from your UK home to the nearest major road.
That has the added advantage of only using the much largermaps when you need to rather than every time you go to the local shops. |
Posted: Fri Jun 10, 2005 7:32 am Post subject: |
julianbarker,
Point taken, but I think the PLUS maps are only available in the Great Britain and Netherlands flavours. Correct me if I'm wrong. |
Posted: Fri Jun 10, 2005 8:39 am Post subject: |
I have seen a German one on the disks - but have not installed it. |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Fri Jun 10, 2005 9:15 am Post subject: |
Any advantage to installing the standard rather than the Plus maps if you are not intending on venturing outside of the UK? |
Posted: Fri Jun 10, 2005 9:58 am Post subject: |
MarkHewitt wrote: | Any advantage to installing the standard rather than the Plus maps if you are not intending on venturing outside of the UK? |
More free space on your Memory card! |
Googlebot Regular Visitor
Posted: Fri Jun 10, 2005 1:10 pm Post subject: |
Personaly I dont see any advantage of having the UK and MRE on the same map.
I think we all have a chance to change to another country's map when we leave the UK, either by ferry/train/air, surely not many of us have a Aquada ?
Now thigns like France or Germany ect with MRE makes sense though ... _________________ iPAQ 2110
Kingston 512Mb SD card
Kingston 1gb CF card
Holux CR-100
Soon to be replaced with TT720 (maybe....) |
Joined: 30/12/2002 17:36:20 Posts: 4918 Location: Oxfordshire, England, UK
Posted: Fri Jun 10, 2005 1:53 pm Post subject: |
I’d think you might see a slightly quicker look up time on the GB only map when compared to the GB Plus map. As there are fewer places on the GB only map. However I can’t prove this, as I don’t have the upgrade version yet.
Garmin Camper 770 LMT-D |
Wilko Regular Visitor
Posted: Fri Jun 10, 2005 5:00 pm Post subject: |
I've got both the Plus and normal map on my SD card now.
There is a slight difference in version numbers, the normal one is v562 and the Plus version is v571, so its probably very slightly upto date than the normal map?
Although the normal v562 map works quite a lot faster in address lookup and map scrolling. |
