Hi204e Occasional Visitor
Posted: Tue Jun 07, 2005 3:34 pm Post subject: TT4.40 Ipaq and GPS wired |
I've TT 4.4 and I have some problem to connect with my gps wired.
TT doesn't find any signal.
This is strange because if I try to use TT GPS (applet) I can configure my gps and I have signal.
Is there some registry in TT that I must modify to use the correct port and receiver ?
Thanks for your support. |
lbendlin Pocket GPS Staff
Posted: Tue Jun 07, 2005 5:10 pm Post subject: |
TTN4 does explicitly NOT support CF GPS receivers. It may work if you select "other BT receiver" but this is not guaranteed. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Jun 08, 2005 11:32 am Post subject: |
Thanks for the tips.
I've tried and I see that can function.
But now I have a little problem: how can I tell to use serial port com1 at BT ?
I see that default port for BT is com8.
should I change registry ? What ?
Thanks |
Posted: Wed Jun 08, 2005 1:45 pm Post subject: |
once you selected "Other BT" it will present you with a list of COPM ports it found on the device. Your COM1: should be listed too. _________________ Lutz
Posted: Wed Jun 08, 2005 2:48 pm Post subject: |
Yes, it's listed, but TT didn't use that.
TT continue to set BT to default port. ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
