oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Thu Jun 02, 2005 6:55 pm Post subject: TTN3 and TTN5 on the same PPC |
I would like to get TTN5 for it's improvments but would not like to loose some of the features that will be dropped from TTN3 . My question is: If I buy a full copy of TTN5 would I be able to run both aplications on one PPC if they were loaded and run from the storage card.
Dave |
lbendlin Pocket GPS Staff
Posted: Thu Jun 02, 2005 7:38 pm Post subject: |
You can do that but you will have to keep independent maps - the versions cannot read the other version's map. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
jonmat Regular Visitor
Posted: Sat Jun 04, 2005 10:13 am Post subject: |
This is very interesting, so is it just a case of installing the TT5 upgrade and it will not overwrite TT3? It would be nice to keep TT3 as well, incase of emergencies! |
insanity Occasional Visitor
Joined: Jun 01, 2005 Posts: 36 Location: Gloucester, UK
Posted: Sat Jun 04, 2005 10:39 am Post subject: |
No - the upgrade info specifically states that your copy of TT3 will not be valid after you activate TT5.
The original poster was talking about buying the full version of TT5, not the upgrade. |
AllenJames Regular Visitor
Posted: Tue Jun 07, 2005 1:23 pm Post subject: |
I can confirm that you cannot have both versions installed at the same time even with both maps on the SD card.
TT5 just wipes out TT3.
I hope TT get the SDK out soon, I need checkpoint !!! _________________ Garmin Edge 800 (cycling)
Magellan GPS315 (Geocaching)
Tomtom Go (driving)
iPhone 5 (phoning) |
Posted: Tue Jun 07, 2005 4:53 pm Post subject: |
AllenJames wrote: | TT5 just wipes out TT3. |
Only if you install to the same folder. _________________ Lutz
Posted: Tue Jun 07, 2005 5:12 pm Post subject: |
I installed TT5 to the SD card and TT3 to default directory.
Whenever I start them up, TT5 always loads. _________________ Garmin Edge 800 (cycling)
Tomtom Go (driving)
Posted: Tue Jun 07, 2005 5:43 pm Post subject: |
Do you have one or two icons? You may want to refresh the shortcut for TTN3 - it may stil show the old icon but point to the TTN5 location.
You can also use the Pocket File explorer to start TTN3 directly. _________________ Lutz
psneddon Occasional Visitor
Posted: Tue Jun 07, 2005 11:17 pm Post subject: |
You could try installing one version to the SD card and one to storage. Also V5 can (with a very small change) read V4 (map v390) maps. I dont know about the maps that come with version 3. |
Posted: Wed Jun 08, 2005 8:56 am Post subject: |
I have tried and tried and I just cannot get both installed.
I choose to install TT3 to main memory (default locations)
I choose to install TT5 to SD Card.
It always appears to put TT5 over the top of TT3 even though I asked it not to put it in main memory.
I done a hard reset last night to see if it was just the PDA being daft but it made no difference and now I have to install all my stuff
Arrrrrrrrrrrrrrgh ! _________________ Garmin Edge 800 (cycling)
Tomtom Go (driving)
Posted: Wed Jun 08, 2005 9:47 am Post subject: |
I know the horse has bolted but before I start installing any new aplication I make a backup with"Sprite Backup Premium Edition" then if disaster strikes a restore of all pre installation programs and settings are only a hard reset and a few screen taps away ,although you may be getting a little tight for space on a 256mb card with 2 sets of maps and backup files
Have you tried installing the first version to the storage using the guide on these forums ( I think ,but not sure it requires a reg hack or moving some files ) and then when that working ok installing the second version to main memory ? Dave |
outie Occasional Visitor
Posted: Wed Jun 08, 2005 10:09 am Post subject: |
psneddon wrote: | You could try installing one version to the SD card and one to storage. Also V5 can (with a very small change) read V4 (map v390) maps. I dont know about the maps that come with version 3. |
Can you share the information about how to read V4 map with V5? Thanks! |
Posted: Wed Jun 08, 2005 10:28 am Post subject: |
Does sprite backup backup the whole contents of the PPC to SD card ?
I have an oldish backup (week ago) would that put all my stuff back ? _________________ Garmin Edge 800 (cycling)
Tomtom Go (driving)
Posted: Wed Jun 08, 2005 2:07 pm Post subject: |
AllenJames wrote: | Does sprite backup backup the whole contents of the PPC to SD card ?
I have an oldish backup (week ago) would that put all my stuff back ? |
You can cofigure it to save what ever you want! but I don't see much piont in saving "all the ppc" you just save the volatile storage as an EXE file. You can however save "all the ppc to your Pc in case of a complete catastrophe..As for your saved backup ..It depends what you used and how it was saved, as to how easy it is to restore
Dave |
Posted: Wed Jun 08, 2005 2:21 pm Post subject: |
continued : but all the information you need to restore should be there.BTW the exe file for my backup is 15.9mb
Dave |
